Do jake brakes damage the engine?
Discussion in 'Questions From New Drivers' started by Phantom307, Nov 29, 2020.
  1. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    I just bought a used truck, both the Jake brakes and the cruise control were disabled in the computer settings. I asked the salesman why in the hell would you disable the jake brakes and he tells me that they are actually bad for the engine and cause a lot of wear and should only be used in downhill application when its absolutely necessary and the damage you're causing to the engine by using it to brake is more expensive than brake pads. Can anyone verify or debunk this?
    Thank you
  3. D.Tibbitt
    148,059
    Tell him to pass the crack pipe
  4. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    That salesman suffers from a whole lotta' WOW.
    Coffey, Bean Jr., Phantom307 and 11 others Thank this.
  5. Michael 247
    Michael 247 Heavy Load Member
    891
    4,665
    Nov 20, 2017
    Dublin Va
    No..it wont hurt the Engine..But I dont leave the Jake Switch on all day...Just use the Jake as needed..I think using the Jake Excessively is a little rough on the Drive Train..Especially in lower gears ...
  6. Moosetek13
    Moosetek13 Road Train Member
    14,665
    18,425
    Nov 1, 2010
    Burnsville, MN
    Ya.
    It's that cruise control that really messes things up.
    Coffey, Dave_in_AZ, Phantom307 and 3 others Thank this.
  7. okiedokie
    okiedokie Road Train Member
    12,273
    91,507
    Jun 13, 2011
    PNWET
    I've heard that Jake shifting is detrimental to the engine. But in certain off road applications I did it.
  8. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    Truck salesmen are more full of #### than dispatchers.
    I heard a truck salesman telling a prospective buyer that automatic trannies are the bomb, and you'll save fuel. If your drivers don't like them, then just #### can them and find some new ones. No problem.
    If I'm in the upper range, my jakes on unless conditions say "don't do that".
  9. supersnackbar
    19,122
    47,172
    Aug 19, 2007
    Your Town, USA
    My 2021 Freightliner with an auto transmission burps the jake to shift quicker. All a jake is, is a compression release. If a salesman said that to me, I'd laugh in his face, then walk out and find a reputable dealer to do business with, because he obviously doesn't know his ### from a hole in the ground.
  10. AModelCat
    158,799
    Lmfao definitely on something.
    All the jake does is open the exhaust valve when the piston is approaching TDC. The old Series 60's used the injector lobe on the cam to run the jake, newer engines (like the ISX I believe) have a dedicated jake lobe on the cam.
    Basically when the jake is on, the pistons compress the air in the cylinders during the compression stroke. Right now the compressed air is acting against the piston travel. Now instead of injecting fuel to make an explosion, the slave piston opens the exhaust valve dumping the compressed air. Now there is no compressed air left in the cylinder to help force the piston down after TDC.
    In a nutshell, the basic operation of the engine has not changed other than compressed air being released from the cylinder.
    As for damage, it ain't gone happen. I've been on hills where literally its a 3rd gear, 3rd stage jake for 20 minutes straight. Nothing blew up or wore out.
  11. Milr72
    Milr72 Medium Load Member
    569
    1,381
    Dec 16, 2011
    S W Missouri
    I read several years ago where one of the execs from one of the fifth wheel manufacturers said that using a Jake brake will wear out the jaws of a fifth wheel faster than a non Jake equipped truck. I think he was smoking some of the same stuff the salesman was!
