Do intrastate carrier need to file IFTA
Discussion in 'Ask An Owner Operator' started by selinrosa, Sep 20, 2020.
  1. selinrosa
    selinrosa Light Load Member
    55
    18
    Aug 30, 2020
    I applied for my authority & got my DOT, MC active lately. If I only plan to operate intrastate with a California base plate, do I still need to file IFTA? Thanks in advance.
  3. GreenPete359
    GreenPete359 Road Train Member
    2,161
    5,120
    Oct 21, 2017
    Driving my recliner
    If you’re not crossing state lines, you don’t need irp or ifta.
    Rideandrepair Thanks this.
  4. abyliks
    abyliks Road Train Member
    3,993
    9,384
    May 2, 2010
    ludlow MA
    Might be different terminology for each state and laws but in MA if you register just commercial truck it’s intrastate and you do not need ifta, apportioned registration (interstate) does to go out of state, I believe you need to file for atleast two states to run them too
    you do still need to enrolled in the wiz quiz program however and most likely a dot number
  5. Excali3ur
    Excali3ur Bobtail Member
    Just applied for my MC and DOT3 etc. As well but you can run within state borders without ifta or apportioned plate. And the mc ucr dot3 will allow you to permit to drive across the line if you need to.
  6. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    Depends on your state. In TN you don’t have to have IFTA or USDOT if you are running intrastate.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    I'm not sure, or I read wrong, if anyone actually answered the question. Yes we know intrastate doesn't need a dot or ifta. That wasn't the question though,
    The question is, does having a US DOT number, even if not going interstate, means he also is required to do IFTA, even if not going out of state. I don't know the answer and I think the op's best bet is to call up OOIDA, but hopefully someone here knows so it can be shared.
    GreenPete359 Thanks this.
  8. selinrosa
    55
    18
    Aug 30, 2020
    DOT is required here in CA even operating intrastate.
    ZVar Thanks this.
  9. GreenPete359
    2,161
    5,120
    Oct 21, 2017
    Driving my recliner
    i can answer that for you. No.
    you can have a US DOT # be registered over 26,001lbs. and still register under a normal commercial tag. (In NJ it would be an X tag.) both IRP & IFTA only become a requirement when you cross a state line (an interstate operation)
    for reference i would point you toward any local construction outfits near you. Look at their Tractors & dump trucks, you won’t find ifta stickers or A tags.
    selinrosa and ZVar Thank this.
  10. abyliks
    3,993
    9,384
    May 2, 2010
    ludlow MA
    Ifta is so you can pay fuel tax for all states ran in, if you are only running one state there is no reason to file it, when you get your plates you actually have to do an estimated mileage in atleast one other state with ifta/irp plates,
    selinrosa Thanks this.
  11. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    And you can run New York [under 26.000#] on that NJ X tag with only a NY HUT decal...
