Do I need to retune SWR if I change antenna angle?
Discussion in 'CB Radio Forum' started by 762x39, Dec 27, 2015.
  1. 762x39
    762x39 Bobtail Member
    39
    10
    Oct 16, 2015
    2015 freightliner Cascadia
    Firestik firefly 4 foot antenna on mirror mount.
    I want to change the angle of the antenna. Right now, my antenna is angled at about 40 degrees. I think it's putting too much stress on the mount so I want to angle it at about 70-80 degrees. SWR is currently at 1:1. Will I need to retune SWR if I change the angle? Also, will changing the angle of the antenna from 40 to 70-80 degrees give me more range? Thanks
  3. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    It wouldn't hurt to check SWR again. I am just wondering why you are tilting a 4ft whip to begin with. Normally, (according to the Wilson antenna engineer that I spoke with) mobile antennas are supposed to be straight up and down. Tilting them distorts the radiation pattern. If tilting the antenna brings the SWR ratio down, then you have other problems, most likely lack of ground plane.
    darthanubis, handlebar, 762x39 and 2 others Thank this.
  4. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Your SWR will go up with a 4ft antenna on the Cascadia the more vertical you go. If you tilt one past about 15 -17 degrees though, you start losing performance, even if you do lower the SWR, which it does. There is no way that I've found to get good performance out of anything less than a 5ft antenna, a top loaded one ( and longer is better, 7ft still is under 13'6" overall) on the Cascadia.
    762x39 and rabbiporkchop Thank this.
  5. 762x39
    39
    10
    Oct 16, 2015
    Thanks for the reply. I tilted the antenna so that the wave pattern would go over the cab (so I was told the reason to tilt it). I don't own a SWR meter and usually have the shop tune it. I should probably get one to save money in the long run. Shop charges me 15 bucks to tune. What 5foot and up antennas do u guys recommend that aren't too heavy? I'm using the Cascadia mirror mount setup. With my current setup I'm getting about 7 miles of distance verified by my buddy that was posted at the truck stop. Will I get more range with a taller antenna? Thanks
  6. mike5511
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Longer is better. Any top loaded fiberglass antenna will do. I use a Skip Shooter -7ft. Looks like it has a nail stuck in the top of it. Some use the 7ft Fire Stick. I've got a old Radio Shack SWR meter I carry with me. Most of the time I can predict what the SWR will be since I drive the same model trucks all the time (I slip seat so different truck every week) but every now and then I get a surprise! So I check mine every time I hook up a radio. These newer CBs will blow the finals quicker than the old ones if your SWR is too high so it is a good idea to always know what it is when you hook your radio to it.
