Do I need the axle/ weight rating sticker on my gooseneck
Discussion in 'Expediter and Hot Shot Trucking Forum' started by baerpath, Jan 7, 2022.
  1. baerpath
    baerpath Light Load Member
    57
    77
    Nov 2, 2019
    Truckstop washed the sticker off my trailer. Does it need to be on there or not ? Contacted Diamond C and they'll send another but wasn't sure that I need it or not
    Lite bug and singlescrewshaker Thank this.
  3. MacLean
    MacLean Road Train Member
    1,266
    3,712
    Sep 12, 2017
    It’s not stamped on a metal tag somewhere? Usually from what I’ve seen on those is the sticker is just to show the axle manufacturer just like you’d see on an RV. I’d think you should have a metal tag somewhere.
  4. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    Are you talking about the tire sticker or the actual VIN plate with GVWR and axle weights on it?
    singlescrewshaker Thanks this.
  5. baerpath
    57
    77
    Nov 2, 2019
  6. Todd727
    300
    583
    Jun 7, 2021
    Did Diamond C send you a PDF of that label to carry while you are waiting for the actual label to show up? The only issue I see is, if you get pulled over, they can't verify the V.I.N. and could jump to a bad conclusion. The GAWR should be stamped on the axles or on tags attached to the axles..
    Lite bug Thanks this.
