Do I need new shocks on the truck, will it ride better?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SLCTrucker, Oct 3, 2011.
  1. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    I see some people saying shocks need to be replaced at 200,000 some at 300,000.
    How do you know when to replace them, I have no leaks & shop tells me they are still ok at 735,000 miles on them?
  3. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I doubt if they're any good. Remove one end and see if it'll cycle easily. You shouldn't be able move it easily.
    If you replace them, don't just go by the size of the bushings. Go to a truck shop and get the proper dampening. Pickup shock will actually fit, but don't work very well :biggrin_2559:
    Does anyone know of a good upgrade over the factory shock?
    SLCTrucker Thanks this.
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Since shocks are a hydraulic mechanism, they build heat when operating. A simple way to determine their condition is to grab them with your hand after coming off the road. If they are warm then they are working.
  5. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    But are they working at 100% of spec?
  6. SLCTrucker
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    Thx, I will try this on my next trip out..
    Considering also adding front air bags to truck also, maybe it will ride better...
  7. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    As a rule if there warm they are working right, if there hot there being over worked and will fail sooner, if there cold there done shot.
    Also if you see any oil on the body of the shock up under the steam shield the oil seal is failing and the shock is all but done.
    OEM shocks are good for about 100000 miles, after market shocks are good to about 150000 miles or so.
    There is an after market shock maker that makes rebuildable shocks for class 8 trucks. I cant find the link for them at the moment but I bet there pricey.:biggrin_2559:
    Scania man and SLCTrucker Thank this.
  8. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Road Kings.
    I'm testing a set right now.
  9. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    I use KONI gas shocks, a little more expensive but worth every penny, they last longer and improves the ride hugely , I always have them put in the truck from new, you would really know the difference on our crap roads
  10. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    I also use adjustable Koni shocks or SV Russian Specials. SV is more expensive but also more durable and they can build them to your specs.
  11. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    I haven't heard of those sv, I'll def look into them, if they're more durable than KONI then they're def worth a look!
