Do i need new clutch with throw out bearing replacement?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, May 17, 2022.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    I think my TOB is going out, it takes a while for clutch to get into gear when i come to a full stop. I also hear a loud chattering that disappears when i press clutch pedal. If i take to get TOB replaced will i need to get clutch replaced as well? Asking to be aware of what the procedure and replacement parts are. Thanks.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Sounds more like a clutch brake to me...
    But if you do tear it all apart, may as well replace everything while you are there.
    Judge, Bean Jr., GYPSY65 and 3 others Thank this.
  4. AModelCat
    154,259
    Clutch brake is the reason for the wait time to put it in gear.
    How often do you grease the throw out bearing?
    I don't know of anyone whose ever just replaced the bearing, they've always put a new clutch in.
    Cattleman84, Bean Jr., GYPSY65 and 2 others Thank this.
  5. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    I grease after every PM probably over greased. Could the clutch break also be the loud chattering I'm hearing?
  6. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Anytime you need to separate engine and transmission you are already paying labor so the extra parts are worth installing if you have some miles on them.. also a good time to check rear seal for leaks .. I’d try clutch brake first as suggested above..
  7. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    Are you keeping the truck for awhile? If so, do clutch WITH installation kit, and rear main seal.
    But as stated above, the delay is the brake. Either it's worn out, or the clutch needs adjusted. It can be cut out and replaced without pulling the tranny.
    That's inexpensive, and a good second step. If the chattering persists, then you can do the clutch. If I were in your shoes, I'd do it in this order:
    1. Adjust clutch correctly. (Not linkage)
    2. Replace brake.
    3. Drop tranny and do everything.
  8. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    the chattering noise, "could be" the shock springs that are mounted in the clutch plate.
    it's best that since it'll all be apart, to replace the many things, others have said. it's a good "insurance" hedge against having to take it all apart again, and pay double the labor costs. the entire parts replaced can be warranted better. also too, you'll have peace of mind for many more miles.
  9. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    Aside from the brake or adjustment being the issue if it is the bearing then other parts won’t be far behind
  10. GYPSY65
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I do have a ? Tho
    Not trying to hijack but it’s related
    Very randomly I will get a squeal when letting the clutch out.
    Not like a metal sound but more like a belt like the sound of engaging the mower deck on a riding mower if that makes sense
    Or a heavy person on a kids go cart
    This is a new ( used ) truck I recently bought and I’m not sure how it was maintained
    When I get home I’m planning to take it to Peterbilt for a harness replacement and just wondering if any have an idea before I get there
    It doesn’t do it all the time and when I accelerate I don’t notice any revs or slippage
    Truck only has 360k on it now. A previous truck I owned I sold with almost 700k on the original clutch but have no idea how the previous owner drove
  11. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Sounds like your pressure plate isn't adjusted correctly to your clutch brake. The chattering is probably your TO bearing, but I have seen a noisy clutch quietened after an adjustment.
    The TO bearing is made onto your pressure plate and not serviceable. If you replace the pressure plate, you also replace both discs and intermediate plate, resurface flywheel, and new pilot bearing.
    wr2001 Thanks this.
