Do I need an ABS code reader?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jlawall, Jan 29, 2011.
  1. jlawall
    jlawall Light Load Member
    63
    15
    Jan 29, 2011
    wapwallopen pa
    I have several van trailers with various ABS systems not functioning. I need to get them into shape and am wondering if Ineed to buy a code reader and if so any recomendations.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ok, lets list all brands of ABS/EBS/ECAS for trailers available on Market:
    Wabco
    Knorr/Bendix/Bosch
    Haldex
    Eaton
    All they support CAN and KWP2000 protocols.
    If your trucks is with trailer CAN wiring you will see trailer ABS/EBS as MID137 unit and you can use system manufacter's software with RP1210 adapter.
    If there is no trailer can in your truck you can use cut in connetor like this
    Sold with Noregon Adapter, found easily this picture with google.
    Some trucks indicate trailer ABS/EBS codes on its diagnostic display, like Volvo, MAN, Freightliner, Mercedes and other... You will see MID 137 PID/SID XXX FMI XXX.
    Just post code here and I will tell you what's that.
    Well, about typical trailer ABS issues. On US trailers 4s/2m ore 2s/2m configurations are used.
    Problem #1: broken ABS wheel speed sensor wiring
    Problem #2: Bent ABS pole rings when someone changed brake shoes/pads
    Problem #3: Air gap between Sensor and tone ring
    Problem #4: bad trailer-trucktor wiring
    Problem #5: Trailer wire damage
    Problem #6: Internal ABS unit damage, usually corroded.
  4. jlawall
    63
    15
    Jan 29, 2011
    wapwallopen pa
    O.K. So when hooked to one of these trailers with my 04 Volvo Ishould get a code in my message center in the dash to identify the location of the malfunction on the trailer?
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    '04 Volvo - Version-II, in Diagnostic Menu find Other System and you will see MID 137 XXX XXX code. But it works if your trailer has CAN. Early ABS equipped trailers were with 5 wire cabels, no CAN and there was wire #5 - warning lamp, that's all. From 2000 in Europe and From 2001 in the USA all trailer brake systems are with CAN, and EU made brake controllers (Wabco and Knorr) support KWP2000 (k-line).
    Before 2000 there was no diagnostic standard for all trailer systems and munfacters used control unit with LED, blinking fault codes, K-L, CAN of exotic standards (ISO), now they use common comunication standard
    If your trailer is with CAN, and trailer-trucktor cabel is OK, you can connect to trailer by truck 9 pin diagnostic connector. You can use adapter connector shown above, but sumtimes there is no diagnostic connector on trailer, no CAN and I have to connect directly to trailer unit from underneath.
    jlawall Thanks this.
