Do any owner operators do EGR cleaning service?
Discussion in 'Ask An Owner Operator' started by LoneRanger, Jan 21, 2022.
  1. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    After speaking with with a member here he tells me that his shop does annual egr valve and cooler cleaning for their trucks using a machine instead of removing the parts.
    I was wondering if any owner operators do this as well or just replace parts.
  3. Siinman
    Siinman Road Train Member
    5,158
    12,909
    Mar 5, 2017
    Kansas City, MO.
    I hear the same thing from some others. I have never done it but my be something I will be doing with the new truck.
  4. JonJon78
    JonJon78 Road Train Member
    7,041
    37,549
    Jul 1, 2018
    Is the "machine" he is referring to, the Diesel Force cleaning from Pittsburgh power?
  5. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Have never done the trucks, but do the reefer egr's every 5-6K hours in a sonic cleaner. Would just have to get a larger one.
  6. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    Speed_Drums Thanks this.
  7. LoneRanger
    3,661
    9,445
    Jun 3, 2018
    I'm referring to the ones you hook up while engine is idling and have a foam type of liquid go through the system.
    never seen the Diesel Force but going to check it out.
    JonJon78 Thanks this.
  8. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    Diesel Force is a foam cleaner. They hook up to the egr and it goes through the whole system. An oil change and a forced regen are required after it's done. They're their own company, it's not from PP.
    I had it done once. IMO you're better off taking the parts off for cleaning and inspection.
    loudtom, rabbiporkchop and 062 Thank this.
  9. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I was going through sensors on a used truck I owned
    Only had 200k when I bought it
    KW in Ogden had it in and they flushed the egr and told me they have guys do it every year as PM and never have issues
    I had no issues after that
    I now do the same thing and so far, no issues but I’m in a newer truck
    I also use Pittsburgh Powers catalyst additive
    Might be snake oil but have friends that swear by it
  10. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    "Do any owner operators do EGR cleaning service?"
    Some do, some don't, some "clean" it out of the system and no more "cleaning" needed.
    mitmaks Thanks this.
