Do “Right Weigh” Scales Really Work?
Discussion in 'Ask An Owner Operator' started by PE_T, Nov 28, 2018.
  1. PE_T
    PE_T Road Train Member
    What are the cons about these devices? I want to try these, but it seems like I would only be getting readings for my drives and trailer. My steer axle has no air bags.
    NightWind and jamespmack Thank this.
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    You can get the same info a lot cheaper with regular old air pressure gauges plumbed into the suspension air lines. Either way, you've got to calibrate it. "Right Weigh" requires scaling the load and adjusting the gauge to read accurately. It's just an air gauge with the dial reading pounds on the axle group. With plain old generic air pressure gauges, you scale the load and note the psi at the weight. Once you figure out where the needle needs to be for a "legal" load, you're good to go.
    abyliks, mitmaks, stwik and 8 others Thank this.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    ...and as for the steers, set your 5th wheel where it needs to be to put 12K on the steers when the drives are at 34K and forget about it. If you aren't over on your drives, you won't be over on your steers. Unless you need the 5th wheel farther back for clearance issues, there really isn't any reason to constantly mess with its position.
    mitmaks, 1johnb, Dino soar and 7 others Thank this.
  5. Banker
    Banker Road Train Member
    4,006
    11,329
    Aug 19, 2012
    I built my truck and trailer with the digital scale on both. It was very helpful at first as I learned my rig and the loads it can haul and how loading it differently effects the weight distribution. The 389 Pete tractor gauge package came with dual suspension wt gauges and these are always right on the money as well. If I had it to do over I would just use the suspension wt gauges that came with the tractor as it usually is close enough for my needs. The digital gauge needs to be on perfectly flat ground to be accurate. I pull on the cat scale platform if I want an exact reading. You also need to calibrate it occasionally using a scale ticket and I pull back on the scale to be on perfectly flat ground when calibrating. They make a sensor for spring axles but I am not sure of the cost.
    jamespmack and PE_T Thank this.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    I had the digital Right Weigh system installed on my new truck. Love it so far. I calibrated it with a load and empty, and now there is no guessing. I had the external Right Weigh system at a previous job, and they were great as well.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,698
    Mar 30, 2014
    I have a pressure gauge on my truck. Around 60 lbs, I'm close, but under 34. Because I have a spread and haul coils, I've got a lot of room to play with.
    jamespmack, adayrider and Banker Thank this.
  8. Banker
    4,006
    11,329
    Aug 19, 2012
    I usually run 32,000lbs on my drives and mine sits dead on 50. I run a 14,600 steer axle and usually carry extra weight there and occasionally some on the trailer. I think either the pressure gauge or the digital scales would be helpful for anyone.
    jamespmack and Bean Jr. Thank this.
  9. jamespmack
    213,427
    They work well. Now I understand why some guys don't see the need. But for the guys hauling multiple coils it gets a bit different than knowing where to place a single coil. Plus they almost never weight the same. 6 inches can make a big difference. You know like one in front, one in rear. Or three, front, middle, and rear. Plus they don't really care once you leave a steel mill. Not gonna be the favorite if you come back and have them move it 6 inches. Plus you don't have to pay for a CAT scales. Yes a air psi load gauge will do a decent job too.
    Bean Jr. and PE_T Thank this.
  10. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    Yes, all you need is a $10 pressure gauge. On the truck I normally drive, 60 psi on the drives is right at 34K, 70 psi on the trailer is right at 34k. You keep the drives 60 or below and the trailer 70 or below, and you'll never get a weight ticket.
    Pedigreed Bulldog and PE_T Thank this.
  11. PE_T
    What’s a good place to buy a pressure gauge for this purpose? Tractor Supply? Home Depot?
