Local mechanic recommend disconnecting the transmission cooler on Eaton 18spd. Fear of water getting into transmission. What is the highest temperature this transmission can operate safely?
Disconnecting Transmission cooler on Eaton 18spd
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mike216, Feb 8, 2019.
Page 1 of 4
What are the circumstances that he believes that it may leak?
You can drive a transmission to about 260, but that's really hot. Same with the axles.
Fear of leaking is not a good rationale for killing any chance it has to get cool. The mechanic to me is a fraidycat for lack of a better term. -
Would it be better to switch to an air cooled rad?
That's all my 18 speed has. It's mounted right behind the trany, not even at the front where it can get cool airx1Heavy Thanks this. -
I wouldn’t operate it without a cooler. An air cooler works just as well. Circulated trans oil instead of antifreeze. Otherwise replace existing one, if worried about it going bad. I’d leave it alone.If antifreeze levels drop check for a leak. Newer 9, 10 speeds don’t have coolers. I like my trans to stay around 160 degrees. Heat is the enemy
A5¢ Thanks this. -
Both of these items should be considered when deciding to remove or switch cooler type on a given application. I local truck that is light duty cycle and hauls light would benefit more from the heat exchanger, where a farm truck the hauls heavy and longer trips to generate the trans heat would be just fine with a oil to air cooler.
The threat of coolant contamination inside the transmission is real and it does happen often. The biggest issue is it delaminates the clutch adhesive on the synchro. With extended running it will ruin the bearings in time and a full rebuild will be needed. Even more havoc is done with automated transmissions and the xy shifter is affected. Bad thing is by the time the contamination is noticed visually it's too late. The damage is done.
Best way to monitor is take an oil sample with your engine oil every PM.Oxbow, black_dog106, Gary Muldewski and 5 others Thank this. -
After any component's oil temp hits 250F its being damaged. Oil breaks down very rapidly at that temperature.
Dino soar, Rideandrepair and A5¢ Thank this. -
I ran mine with no cooler at all for close to a year with no ill effects. I have a guage and saw no real increase in temps. I noticed the difference im the winter though. That was the reason l finally fixed it lol. That was grossing 135-140 everyday so l think you'll be fine grossing 80g.
bbechtel16 and Rideandrepair Thank this. -
Page 1 of 4
