Disc brakes on truck and drums on trailer problem
Discussion in 'Ask An Owner Operator' started by joseph1853, Mar 23, 2022.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Ok, so I don't know whether or not to post this on the mechanic's area or the owner op area. Seems like the owner ops have more understanding of trucks than a lot of mechanics do. Anyways I've noticed something a little disturbing the last time it rained. I was coming up to a gas station to stop and started slowing down and the loaded trailer I was hauling started to push my truck. I actually felt the antilock brakes doing their thing. I ended up sliding a bit past the turn. This has happened before but at that time I didn't think anything of it. I was on a curve and it had just started to rain and in the middle of the curve I decided to slow down a bit and the trailer started pushing my truck into a jackknife position but was able to pull out of it before heading off into the ditch. Just thought there was oil or something causing me to slide. So my original thought was the trailer brakes need to be adjusted or they were not working properly so I had the shop I work out of check them and they said they were fine that they were self-adjusting and that the reason for the issue was that the disk brakes on my truck were working better then the drum trailer brakes were and there was nothing they could do about it. I'm thinking well this doesn't seem safe at all considering the two instances I've experienced so far. I mean if there was a car in front of me I would have hit them. What are ya'lls thoughts on this?
  3. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Have had all disc brakes on tractors since 2007 and a lot of trailers with discs's. Get used to the disc's and you have what you described. Also works the other way when the trailer has them and the tractor doesn't. Was a learning curve for the drivers.
    joseph1853 Thanks this.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Don’t even need the drum/disc mix to make things weird. ABS non-ABS combinations can be fun. Can’t say I’m a big fan of the foot valves in the ABS trucks. Any kind of driver input brake modulation kind of went out the window when those came along. Brakes now are like ceramic clutches, they should just have an on/off switch on the dash.
  5. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Yep definitely a learning curve. This is the first truck ive had with disk brakes. At first I thought they were great because of how well they work that is on dry ground. I mean i dont have to hardly press down on the peddle in comparison to the other trucks I've driven with drums. The other thing about my set up is i don't have a trailer brake. I could compinsate for the descrepancy if i did. They say there not that hard to add, so maybe ill do that.
  6. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    Different crack pressure I believe, the last company truck I had disks on ~5 years ago did the same thing.
    a full disk set up on truck/trailer is actually impressive, they will stop on a dime and bring back change compared to drum
  7. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I agree.
  8. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    With your setup.. learn how much you need to gently ride ( dry your disks) the brakes prior to stopping in wet conditions.
    Just a learning curve.
  9. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    A pull on the Johnson bar should straighten it out.
  10. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Braking in a curve is a recipe for disaster no matter what.
