Disc brakes on a semi?
Discussion in 'Questions From New Drivers' started by Sportster2000, Apr 29, 2008.
  1. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    I have heard of them before and finally saw a truck that had them on there a couple of weeks back. Well I am going to be driving one. Question is, is the stopping power of the disc brake more or less than the drum brakes? Is the difference noticeable? Just wondering. :biggrin_25525:
  3. Lurchgs
    Lurchgs Road Train Member
    2,122
    308
    Feb 13, 2008
    Denver, CO
    Gonna depend on the size of the rotor and the pads. I would *guess*, however, that it's probably shorter stopping distance. Probably noticeably so.
    The Gov't is contemplating mandating shorter stopping distances for big rigs, last I heard - to go into effect this summer, I think. In effect, requiring disc brakes - I think all around on the tractor.
    In discussion, the general response was "Gonna need a darn crane to put those rotors on! " They'll probably have to be vented and/or slotted, too.
    Farmerbob1 Thanks this.
  4. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    From what a mechanic told me you do not want to mix and match the drums on a trailer and disc on the tractor.
  5. Lurchgs
    2,122
    308
    Feb 13, 2008
    Denver, CO
    it would definitely be sub-optimal, but it could be done - particularly if the trailer is ABS
  6. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    So what you are saying about the trailer having drum brakes and the truck having disc brakes that the truck will try to slow down faster? So then that would mean that the trailer would not really be doing that much braking at all. Am I correct on this thought?
  7. Lurchgs
    2,122
    308
    Feb 13, 2008
    Denver, CO
    I'd not mix/match unless the trailer had ABS.. then it would slow down just as it does now - but yeah, most of the braking woudl come from the tractor
  8. Lone Ranger
    Lone Ranger Light Load Member
    53
    10
    Apr 26, 2008
    Dallas, Texas
    Disk brakes are much better than drum brakes, both in stopping force and fade resisting.
    The disk brake system weighs less, and there are less moving parts.
    The best thing about disks is that on a long downgrade, they do not fade nearly as much or as fast as drum brakes. When drums get hot they expand and it takes more brake pressure to maintain the stopping force. The shoes have to push harder and further.
    When disk get hot they expand too, but the brakes are squeezeing the disk, so as the disks expand, they get squeezed even harder.
    As for mixing them, that doesn't seem to be an option to avoid since most of the trailers made here (USA) have drum brakes. Disks are more expensive.
  9. Native Dancer
    Native Dancer Heavy Load Member
    978
    3,259
    Dec 28, 2007
    Portland, Or.
    Picked up axles at Hendrickson a few weeks ago and delivered them to a trailer manufaturer. There were some axles there with disc brakes and I was told they were available as an option. The rotors and pads didn't look that big. The brake pots were mounted perpendicular to the rotors.
  10. dieselhound
    dieselhound Medium Load Member
    410
    39
    Mar 23, 2008
    Erie,PA
    I would guess the pads wouldn't be big because the friction area causing heat. The heat is what would bother me. The bigger disc could cool off without cracking. I can imagine the replacement costs as to shoes and drums.
  11. Lurchgs
    2,122
    308
    Feb 13, 2008
    Denver, CO
    I think the pads would HAVE to be big. Keep in mind, friction is what stops that 80,000 pound gorilla. The heat, though, is why I mentioned vented or slotted rotors.. very little loss of friction, but it keeps things a lot cooler.
    As for the cost.. I'm not going anywhere NEAR that one
