So my Tractor that I use and occasionally a few of the trailers that I pull have Disc brakes all around… they are sooo much better than drum brakes and despite the performance.. my only grip about them is I am unable to check the pads.. at all because of everything in the way. Our mechanics have a strict interval when they pull the wheels and check the pads and rotors because if the rotors get chewed up… our mechanic emphasized that’s it’s a real ##### to replace them
Which pegs the question… how does DOT inspect disc brakes? I never had a Level 1 with the setup and honestly I’m looking forward to it… as far as the brakes goes… they can’t check anything but the rotors and the front slack adjusters
reminds me of when ELD came out and DOT officers were clueless
Disc Brakes and DOT Brake Check
Discussion in 'Experienced Truckers' Advice' started by BigNorm4Life, May 16, 2023.
tscottme, D.Tibbitt, gentleroger and 1 other person Thank this.
Depends if they have the backing plate or not. I’ve always been just let go when it came to Disc but have had several guys not give me a sticker because it had disk.
Although the inspector did slide around on his creeper front to back there wasn’t anything to check in regards to brakes. Unless something crazy they can see like cracked disks or pads falling out.
Told me that disc brakes make his life a lot easier since there’s nothing to measure.
Ended up with two stickers and a clean inspection report.
I’ll never buy anymore equipment with drum brakes..just a big pia.RockinChair, alds, ibcalm19 and 6 others Thank this. -
I was told they look for rusty rotor. Pads not touching rotor if rust on face.
bzinger, BobO1176, Accidental Trucker and 1 other person Thank this. -
See Comment #4.
(1) Heavy Duty - Air Disc Brake Inspection - YouTube
Note at 1:05 the wear indicators cast into the carrier and caliper for checking with the wheel on.D.Tibbitt, gentleroger and Studebaker Hawk Thank this. -
I don’t drive a standard size day cab… I drive a local city tractor so things are smaller
D.Tibbitt Thanks this. -
Magoo1968, D.Tibbitt, Studebaker Hawk and 2 others Thank this.
When i see the occasional entire brake shoe or chunk of a drum on the side of the highway, I marvel at how did inspection and maintenance get to that level.
Disc brakes will fall to the same failures. the video did an excellent job of explaining the wear indicators, but the given the trucking industries penchant for ignoring preventive maintenance, as more and more disc brakes are installed, the inspectors are going to have to finally do their job.D.Tibbitt and gentleroger Thank this. -
Studebaker Hawk Thanks this.
Another vote in favor of discs. I check mine every couple years. They just about never wear out. Seriously, I'm over a million miles on my tractor and have done pads once. No rotors. No lines. Passes inspections, stops when I need it to.
I have also heard rotors are a huge job on a disc tractor, not sure about trailer but probably the same. I do not look forward to the day.Rideandrepair, D.Tibbitt, JonJon78 and 1 other person Thank this.
