Digital odometer display not displaying anything .
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CdnCutie, May 26, 2014.
  1. CdnCutie
    CdnCutie Bobtail Member
    2013 Freightliner Coronado the digital odometer display is no longer displaying anything. Would it be something as simple as a blown fuse? If so where would that be located?
    Thanks!
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    not sure about the corenado, but on Columbia, the same fuse controls all the gauges. In your case if it were a fuse, the odom wouldn't be the only problem. First off, check if the ecm is recording odom with a scan gaudge. Any shop should be able to check. If its just the odom display not working, it could be a lose/broken conection under dash.
  4. CdnCutie
    Thank you Richter!
  5. Ridgeline
    22,101
    113,191
    You need to replace the speedo unit, there is no real fix for it that can be done by either a mechanic or by Freightliner, they are pretty much scrap if they don't display.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    In all clusters like this, I have only seen 1 fuse for the whole cluster, so I doubt a fuse is your problem. With a data link problem, you will get some sort of feeback, along the lines of "No Data" on the odometer display, so I don't think it's a data link problem either. If all the other gauges work, I'm leaning toward the cluster being bad.
  7. Akosh
    Akosh Bobtail Member
    I have 2021 freghtliner cascadia .,., odometr not working? and ambient temperature sensor not working (I was exchange 2 time the sensor)
  8. Alinatrucking
    Alinatrucking Bobtail Member
    8
    Mar 27, 2024
    Hello, was you able to solve the problem?
    My odometer also freezed, and ambient temperature sensor is changed two times but still has the code telling that it’s not working!
    Also, recently, the DEF light started blinking red even though it is full the voltage reading disappeared as well!
  9. Zekria99
    Zekria99 Light Load Member
    75
    8
    Nov 25, 2010
    Toronto,Ontario
  10. Zekria99
    75
    8
    Nov 25, 2010
    Toronto,Ontario
    Hi I have the same problem did you find the problem
  11. Alinatrucking
    8
    Mar 27, 2024
    Change or repair your CPC4 module, you can do it in Tennessee close to Nashville area, it is called CPC doctor, look up online find a place talk to them get the pricing pull up your CPC from your truck mail it to them. Wait couple days receive it put it back. They also have to update the software.
    It’s better to do it now rather than later because you will have more issues. For example, your gas pedal will stop working and other things.
