Differential Pressure sensor where is located on International Pro Star 2008
Discussion in 'International Forum' started by Samall02, Aug 19, 2014.
  1. Samall02
    Samall02 Bobtail Member
    7
    Can anyone help me where is Differential Pressure sensor located on my International pro star 2008?
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Since that's a DPF sensor, probably on the DPF unit itself.
  4. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    It also can be used on the engine itself to help the ECM control the amount of exhaust gas to recirculate back into the intake from the EGR valve. It is located on the intake side of the engine. At least on my CM871 ISX it is located on the intake manifold near where the EGR mixing pipe connects to the manifold as well. It sits on top of the manifold and has two small tubes that run down to the mixing pipe.
    Samall02 Thanks this.
  5. Bcase
    Bcase Bobtail Member
    Aug 20, 2014
    Mission Viejo, CA
    Depending on the engine it could be in two places.
    The differential pressure sensor is a small black box mounted either in top of the filter unit or on the frame directly above the filter.
    Follow the hard metal lines coming from in front and behind the filter module. Those both lead directly to the differential pressure sensor.
  6. CMCtech
    CMCtech Bobtail Member
    28
    11
    Feb 20, 2013
    It's right next to your fuel pump
  7. Samall02
    7
    Do you maybe know why my check engine light turn on almost always when I am driving up to the hill?
  8. CMCtech
    28
    11
    Feb 20, 2013
    Does your oil pressure drop?
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Probably same reason as most pro stars Emmision fault
  10. Samall02
    7
  11. CMCtech
    28
    11
    Feb 20, 2013
    Clean the differential pressure sensor tubes and the sensor on the intake
