Differential models
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Leftlanemilktrain, Aug 4, 2020.
  1. Leftlanemilktrain
    Leftlanemilktrain Bobtail Member
    13
    20
    Aug 4, 2020
    What is the difference between a dhs40 and a dsp40 diff?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,699
    Mar 30, 2014
    P stands for pump. Apparently not necessary, as i switched mine from DSP402 to DS402
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    The P in DSP stands for planetary double reduction.
    I believe its DSH and the H is for High performance or high horsepower applications.
    Google "Dana Service manual" and it calls out all the meanings for the model numbers.
  5. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    I'm not sure that a DSP40 is "double planetary", but I do know that I was talking about a completely different rear-end than the op was asking about. DS402p is an Eaton, and the p stands for pump in that one.
    To quote Rosanna Rosanna Danna, "nevermind!"
    spsauerland and Goodysnap Thank this.
  6. dirthaller
    dirthaller Road Train Member
    1,015
    11,800
    Sep 22, 2011
    Coloratah
    DSH has a 3/4” larger diameter ring gear. It’s an oddball.
    Bean Jr. Thanks this.
  7. Leftlanemilktrain
    13
    20
    Aug 4, 2020
    Would either these be considered a super 40?
  8. dirthaller
    1,015
    11,800
    Sep 22, 2011
    Coloratah
    I would not consider a dsp40 a “super 40” however, back in the day, a ds405 was considered a super 40 because they had heavier axle housings....even though they had the same basic differential as a ds380, ds402, ds404 and dsp40. Are you confused now?
    The only reason to spec a dsh40 is to satisfy hp/torque requirements for the truck manufacturer if you insist on 600/2050 in a standard road truck application.
    spsauerland Thanks this.
  9. dirthaller
    1,015
    11,800
    Sep 22, 2011
    Coloratah
  10. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    DS405 is an Eaton. DSP40 and DSH40 are Dana.
  11. dirthaller
    1,015
    11,800
    Sep 22, 2011
    Coloratah
    I’ve installed ds404 in dsp40 housings as a direct swap
