Differential locks Unlock
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lz1fkg, Dec 10, 2015.
  1. lz1fkg
    lz1fkg Bobtail Member
    My differential locks and power divder disengage when i shift onto the high side. How can I bypass this. I need them to work on the high sid as well as their needed in the woods?
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Welcome to the forum. Let me give you some advice to make your visits more productive. When you are asking for information, make sure that you give us as much information on the component as you can. In the case, a year, make model would be nice to know.
    Heavyd, lz1fkg and AModelCat Thank this.
  4. AModelCat
    154,214
    I'm guessing you probably have an air valve connected to the airline from the range selector. Probably does something like cut airflow from the lockers and exhausts it once you hit high range. Best bet would be to trace the lines from the transmission and lockers and see if they meet at a common valve.
    lz1fkg and not4hire Thank this.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Lockers are made for slow speeds, every truck I ever drove would automatically disengage them above 20mph. Power divider is good for any speed
    GrapeApe Thanks this.
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    That was my thinking as well, but didn't want to say it since I'm a mechanic and don't have a lot of wheel time. I have driven in snow, but not much off-road. In my almost getting stuck in the snow experiences, using the diff locks and power divider were good to get me moving, but not needed once I was moving. I think they'd be more dangerous than helpful at higher speeds.
  7. AModelCat
    154,214
    IMO they're more of a situational thing. Sometimes you need the speed and the extra traction to pull a hill in the bush. Having the diffs unlocked could cause you to spin out. I'm thinking that's the OP's reasoning. Biggest thing is unlocking them before you hit the corners so you can turn.
    lz1fkg Thanks this.
  8. lz1fkg
    2001 Pete 379 550 cat 18 speed
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    It depends on the brand of gear, etc., but I routinely ran four-way lockers up to 35-ish mph for 100 or more miles--no harm, no foul--doing oilfield/off road hauling. Power divider would stay in pretty much all winter regardless of speed. My trucks were all newer, so the diff lock kick-out was adjusted in the ECM by the dealer--which had to be done on some of them as they would kick out at about 25 mph.
    Plus I had to get the dealer to kill the "stupid, you left your power divider/diffs locked" alarm.
    mountaingote Thanks this.
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    That's all air, no electronics or ECM controls for them. You'll have to follow the airlines from them, they'll go to pilot valve (basically an air operated relay). You'll have to plug the airline that comes from the range selector to that pilot valve. That will disable the range selector shutting them off and that's all I would do so you can easily put it back to OEM.
    mountaingote and lz1fkg Thank this.
