Different tire size on Rear axles
Discussion in 'Ask An Owner Operator' started by Brandon0928, Jul 28, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    Just bought a truck and On the back rear axle they have 295/75r22.5 and the front rear axle is 275/80r22.5. The rear axle seems like the tires are quite a bit wider. Should I be real concerned about this ?
    Rideandrepair Thanks this.
  3. Flying V
    Flying V Bobtail Member
    5
    Jul 28, 2022
    No, they are interchangeable.
    Michelin primarily uses the 275 size, but almost everyone else uses the 295 size.
    The 295's will be a little wider, but the Overall Diameter is indistinguishable and has almost no effect on wear. Just keep them inflated!
  4. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    They are the same, although if they couldn’t put a match set of drives on the truck I’d love to know what other corners they hacked as well….
  5. Brandon0928
    184
    105
    May 14, 2022
    Thanks for the reply ! Is there a reasoning behind that ? Seems a little silly why everyone else would use 295s!
  6. Brandon0928
    184
    105
    May 14, 2022
    I will let you know the more things that find along the way! LOL Hopefully it’s minimal!
  7. Flying V
    5
    Jul 28, 2022
    I'm sure there are many reasons that I don't know, but I think it comes down to the Manufacturers determining which size performed better for them in their testing and development. Continental and BF Goodrich (BFG is Michelin Owned) used to be 100% on the 275/80 size, but have both moved to 295/75 and I've seen some Michelin 295/75 I believe.
    Rideandrepair and Brandon0928 Thank this.
  8. SmallPackage
    5,274
    16,448
    Dec 20, 2019
    Marion Texas
    It’s called a plus size fitment. You get a wider tread at the same diameter. Bigger footprint with the same height.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    The bigger footprint comes in handy up here in Canada where many places determine spring weight restrictions by the mm width of the tire ..
    Brandon0928 and Flying V Thank this.
