Differences between the 379 and 389
Discussion in 'Peterbilt Forum' started by snowbird_89, Jul 22, 2012.
  1. snowbird_89
    snowbird_89 Road Train Member
    1,028
    824
    Aug 21, 2009
    Massachusetts
    What are the differences between the 379 and 389? I know one major difference is the headlights. Other than that, I don't see that much of a difference between the two models. I love both trucks.
  3. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    none really... just the headlights and on most factory trucks the fatter stack, dash is the same in both trucks so really nothing
  4. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    The hood, fender, lights and trim nothing else...
    SHO-TYME Thanks this.
  5. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    To start with the BBC of the 389 is 4" longer than the extended hood 379. Every piece of the hood is different. The 389 has longer springs on the steer axle and different frame horns and bumpers. The cabs seem to be the same as the 2006 and later 379's, but they are mounted slightly higher on the frame. They also use the same radiator as KW now.
  6. danmissouri
    danmissouri Light Load Member
    88
    42
    Jul 25, 2010
    naperville,il.
    389's hood is also alittle longer, the biggest difference is what you can't see. The fatter stacks that hawkjr was refering to is part of the pollution system. That's that Regen system ,with the filter that's about $4,000 (just for the part) when it cracks or gets plugged up. Not to mention it drops your fuel mileage by a bunch, always regenerating. The newer ones are now using DEF. (Anyone notice how many 389's have the DEF tank on the passenger side? Good thinking.) They had to warm over the 389's appearance to get anyone to buy them, most people had alot of questions about buying anything newer than an '07.
  7. Dexterr
    Dexterr Medium Load Member
    384
    327
    Jul 25, 2011
    Lafourche parish
    The headlights,the ventless windows,and the grill is more rounder at the edges, the 06-07 379s had the ventless windows though
  8. snowbird_89
    1,028
    824
    Aug 21, 2009
    Massachusetts
    I don't know why Peterbilt puts the DEF tank on the passenger side. Kenworth beats them in competition for that.
  9. superman91684
    superman91684 Bobtail Member
    12
    Jan 25, 2009
    Boston, MA
    You can get the def tank on whatever side you spec, I'm driving a 2012 388 with the tank on the drivers side.
  10. danmissouri
    88
    42
    Jul 25, 2010
    naperville,il.
    I know, I've seen them on both sides. Talking to a guy out of Canada. He had a Teal Green 389 (really nice). It was a company truck that someone had put the tank on the pass. side. He said as nice as the truck looks, he hated the deal with pulling into the fuel islands the wrong direction. Says he's not too popular sometimes.
    RefMata Thanks this.
  11. PeteSalesGuy
    PeteSalesGuy Light Load Member
    81
    56
    Aug 27, 2012
    Buffalo, NY
    DEF tank location is selected by the customer or whomever orders the truck. Some DEF locations are due to APU room, etc. and may be required by such needs. Also DEF tank size is based upon fuel tank total capacity however a larger DEF tank can be ordered to reduce fill-up timing but like anything bigger, adds weight to the chassis. You can put the DEF tank on the right side on a KW as well......
    DrtyDiesel Thanks this.
