In my CDL booklet, it mentions "front axle," and "steering axle." Are the two different?
I know that's probably a silly question, but I'm learning, especially with the help of you guys.
Thanks,
Bird
Differences Between Axles?
Discussion in 'Questions From New Drivers' started by FatBird11, Mar 4, 2019.
FatBird11 Thanks this.
Its the same thing
That’s how they communicate the two axles of your tandems. Either truck or trailer. Always front is the front tandem axle. Always steers are steers.
Steers are never called front.Dave_in_AZ and FatBird11 Thank this. -
You are good in any state if the steers are under 11500.. Drives under 34k and tandems under 34k. Scales measure those three and sum them up for gross weight.. Which should be under 80k lbs.
In theory, the “front axle” could be the forward axle of a dual axle group. But generally speaking, IMO, the steer axle should always be referred to as the “steer axle”. If the book is interchanging the two, it shouldn’t. But I imagine the steer axle is often referred to as the front axle.
Troglodytes.
fss99701, FatBird11, Bean Jr. and 1 other person Thank this. -
Dave_in_AZ Thanks this.
I am a citizen of the United States and I am also an American. Both terms describe me. The difference though is the CONTEXT of how they are used. Steering and front both say the same thing, but are different in what the subject is. This is a great example of why regulations can be so dang frustrating because depending on the context they can seem to clash. Example. If a regulation said a single axle can have 17,000 on it does this mean a regulation saying the steering axle can have that much? No, it doesn't because the rules limit the steers. I made up numbers here. Just never forget the context of how a word is used especially in regulations. Front and steer can be used interchangeably, just beware of that one exception.
FatBird11 and brian991219 Thank this. -
REALITY098765 Thanks this.
