Difference between PDL lock and off road switch
Discussion in 'Questions From New Drivers' started by Evl1, Apr 10, 2014.
  1. Evl1
    Evl1 Light Load Member
    61
    31
    Nov 17, 2013
    Albany, NY
    I just got into a 2014 Prostar (really a 2013) and saw two switches, one for PDL lock and the other for off road. What is the difference between the two and when would I use one over the other or both? Your knowledge is greatly appreciated!
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    The "off-road" switch is used when the GPS doesn't comport with reality and you have to make the turn onto a road that the GPS thinks is paved but is not.
    Lepton1, Cyotee, windsmith and 2 others Thank this.
  4. Pasquale
    Pasquale Medium Load Member
    480
    120
    Dec 18, 2013
    You're right. It's also for all wheel drive functionality also if he would need it. ThAt truck also has a turbo button for advanced operation and maneuvering.
  5. Pasquale
    480
    120
    Dec 18, 2013
    The PDL for your power door lock operation. The off road has a driver feedback tutorial functionality option as well.
  6. Evl1
    61
    31
    Nov 17, 2013
    Albany, NY
    Is it sort of like a car with a 4wd system? So the off road locks the diff but allows for some slips and the PDL lock locks them and allows for no slip?
  7. Pasquale
    480
    120
    Dec 18, 2013
    Not exactly. The driver tutorial switch will decipher the difference occasionally and will allow driver options of choices to function truck specifically sand without pheasability.
  8. Pasquale
    480
    120
    Dec 18, 2013
    Does it have the Dip button as well? May be dip? Not sure exactly. nse
  9. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    If you leave the mud and snow switch on, like I did all last winter, it snows everywhere. I shut it off and the weather is nice again. Sorry
    Mr Ed and STexan Thank this.
  10. Pasquale
    480
    120
    Dec 18, 2013
    I thinks that's the ats button?
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    The PDL (power divider lock) is only used in times of low traction at steady speeds. You might use it through a snow storm, traveling down a muddy road or even backing under a trailer where your tires might spin out. It is a separate unit from both differentials that will apply more power to the wheels that have grip and less power to the ones that are spinning. It's kind of like a limited slip differential on a car but a little more sophisticated. Do not use it full time like at highway speeds on dry pavement or you might tear up axles, gears and seals. Use it only like driving slower in the snow where your tires can spin out. Failure to use can also cause problems if you are constantly spinning in snow. I wouldn't use it above 35 mph and for short periods or it will heat up from abuse. You can engage and disengage it while moving but not under throttle. You will get a solid light when engaged. If you are going too fast for it the light will flash about once a second, slow down or turn it off. Some trucks have an audible alarm if you are traveling too fast. If it flashes real fast like 2 times a second indicates you have problems with it.
    Off road is your differential lock and should only be used in a pickle like stuck when stationary or below low speeds like 25 mph or like climbing a snow covered hill at low speed. If I ain't mistaken which I don't know a Prostar but is the RF and RR drive tires.
    The two switches can be used together for maximum traction but at only low speeds and conditions that warrant it, like trying to get up a snow covered hill at 15 mph.
