Difference between dsp41 3.36 ratio and dsp40 3.36 ratio
Discussion in 'Trucks [ Eighteen Wheelers ]' started by D&i, Aug 21, 2017.
The dsp41 is rated a little heavier duty then the dsp40 -
If i remember correctly the 41 has heat treated gears
Oxbow Thanks this. -
Thought the 41 used thicker axle housing and better hardened spindles. Kinda the wide based wheel spec. Pretty sure carriers are exact same.
