Difference between 2 & 3 rear Axles?????
Discussion in 'Questions From New Drivers' started by Hoodoo Voodoo, Dec 6, 2016.
  1. Hoodoo Voodoo
    Hoodoo Voodoo Medium Load Member
    Being the Newbie that I am I was wondering the difference between two or three Axel's on the rear of the trucks? I can only assume that this would be very beneficial 4 Heavy Haul. Or maybe if you were into hill climbing competitions. LOL but seriously if you guys can shed some light on this the Curious side of me would really appreciate it thanks in advance.
  3. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Mostly for legal weight limits aka permit loads.
    Lav-25, Grumppy and Hoodoo Voodoo Thank this.
  4. Ruthless
    Ruthless Road Train Member
    8,786
    85,961
    Aug 28, 2010
    The City.
    More axles don't help with hill climbs per se, more axles can haul more weight.
    Lav-25, wore out, Deere hunter and 6 others Thank this.
  5. TripleSix
    127,948
    Heavyhaul to trucking is like an 18 wheeler is to a car. Cars are called 4 wheelers, remember? Instead of counting the wheels, heavyhaul counts the axles. The tractor you are referring to is called a 4 axle. Your normal everyday freight truck is called a 5 axle rig. And the general consensus is 12000+34000+34000 for the interstate unless you have a spread axle trailer (and that depends on your axle spacing). The heavyhaul 4axle tractor goes 20000+20000+20000+20000 (less in some areas, more in others (and that depends on your axle spacing)).
    Generally, the 4 axle tractors will have 2 drive axles just like the ordinary trucks, but a dummy axle. So it's not necessarily about the traction as it is about the weight (refer to @Ruthless's post). However there are some 4 axles that have 3 interlocking drive axles. This type truck is called a "tri-drive" and it is beastly. It's not easy to drive...not easy at all, because the extra drive axle makes it difficult to get weight on the steer axle and steer unless you are loaded freakin heavy. So, instead of turning, it will want to slide around c
    And a tri-drive is H E A V Y. Bobtail, full of gear will be around 40000 lbs. Tri-drives usually pull the biggest of loads. Normally the 13 and 19 axles or bigger.
    Lav-25, Deere hunter, Grumppy and 6 others Thank this.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    You see these rigs out west and northern plains a lot. They can license for and legally manage more gross weight and theoretically charge more per load. They add more square inches to spread the extra weight to reduce road wear and tear. Also, the extra axles, add additional braking ability, needed for the additional weight.
    In Michigan, Ohio etc??? those bazillion axle rigs are beyond my comprehension what they are doing gross weight wise, or how much has to do with frost laws and heavily weight-regulated roads
    Lepton1 and Hoodoo Voodoo Thank this.
  7. AModelCat
    154,240
    When you get into trucks with 3 live rear axles (aka tri drives), you also get the benefits of better traction. Lock everything in and you have all 12 rear tires putting power to the ground. Just good luck with the steering lol.
  8. AModelCat
    154,240
    The key with those tri drives is to set them up for proper weight distribution. My old man had to bolt his logging bunk on to the frame 22 inches ahead of the center diff in order to maximize the payload on all axles. If you're pulling low beds you need one heck of a long neck to reach up there lol.
  9. Hoodoo Voodoo
    I'm not buying anything..... Yet? I was just looking around on Craigslist today Nationwide and I was coming across quite a few of those 4 Axel's. I haven't come across to tri- Drive yet. I was just wondering about the pros and cons that's all. Hey @TripleSix I'll be posting some pics of those bikes that I've built over the years I don't have anything downloaded for pictures and I've got to dig out hard copies but I'll get them on here to you and I haven't forgot thanks for all your help
    Deere hunter and TripleSix Thank this.
  10. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Mad Monkey, you see 4 axles a lot in the PNW. Up in that area you see a lot of what is referred to as maxi trucks, or some call them heavy haul, but it's not the same as hauling heavy equipment. Depending on state and axle spacing, I believe that they are set up to legally gross up to 105,000 or so. 65,000 or so loads. Generally it's a normal tandem drive, with a drop axle in front of those. The trailers are 4 axle, or 2 or 3 axle with 1 or 2 drop axles.
    Hoodoo Voodoo Thanks this.
  11. TripleSix
    127,948
    Unless you're pulling a 19 axle or way up in the Territories, a tri-drive is wayyyyyyyyy overkill. In Canada, where the dummy lift axle isn't kosher, and in the states bordering Canada, they run these really beefy 3 axles with full locking diffs. These are called Heavy Three's. If youre going to Hell, its the truck that you want to take you there. Before you throw down your money, keep this in mind: tbose locking diffs, beefy axles and thock frame rails adds alot of weight. Where your mega fleet trucks starts in at 17000 to 18000, the heavy 3 is going to start in at 25000 lbs.
    "But Six, it will bring me bck from Hell...isnt that worth the extra weight?"
    Honestly, the places where you want the lightest truck, and come in with the bare minimum fuel level, so they can load you with as much product as legally possible DON'T PAY SQUAT. Alas, most people just stick with what they know.
    If you really want an education, take a job with a company that runs the US, Canada, Alaska and the Territories. Even the grocery haulers are rugged. You will see doorslammer rigs with 4-5 axles under the trailer. You will be sitting in a mega carrier box truck backed up to a dock, and the toughest van truck you've ever seen backs in next to you.
    Deere hunter, snowman1980, dca and 2 others Thank this.
