Diff lock light flashing, interaxle light on, is that correct?
Discussion in 'Volvo Forum' started by ErieMcDreary, Dec 22, 2021.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    2016 VNL. I got hung a little on a snowy parking lot, so I tried to engage my axle lock, I noticed the diff lock light flashing, the interaxle lock is constant on, with switches on, goes off with switches off.
    Had dealer check it, first issue was a seized-up piston inside the diff. They corrected it.
    Took the truck, checked it later, diff lock light still flashing, back to dealer, needs wiring harness. They showed me the bad connector, so I ok'd it, they installed that.
    Diff lock still flashing!!
    Shop foreman told me service writer told him that I said the light was coming on intermittently while driving.
    I said no that's not the problem, and from now on I will speak directly to you!
    Anyway, he said the flashing light is normal and how it's supposed to work
    Is that correct? Is that how everyone else's lights work?
    I did throw the switches and drove a little slowly and it is definitely working.
  3. 201
    201 Road Train Member
    12,620
    25,902
    Apr 16, 2014
    high plains colorado
    Well, a flashing light is never good, it usually indicates a warning. I always had older trucks that never did that, perhaps the new ones flash. With all the computer controls today, sounds like something wan't "cleared" electronically.
  4. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    When I had my Volvo it did the same thing so as to worn you the dif is engaged
  5. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Well, I guess it's normal then.
    Thank you.
  6. 201
    12,620
    25,902
    Apr 16, 2014
    Piece of electrical tape will fix it,,, :biggrin_25522:
    jsnell Thanks this.
  7. QUALITYTRUCK
    1,816
    1,781
    Jun 14, 2009
    romulus,mi
    Actually one of Volvo better ideas (go figure) If engaged will let driver know by flashing instead of blending in with hundreds of other lights on dash that are on solid and may just trick your mind by blending in.
  8. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Maybe, I guess. The interaxle lock light stays steady, just the diff lock light blinks, they're side by side, and there really aren't many other lights to worry about.
  9. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Take apart wiring harness at the front diff. clean wiring connection.then check the condition of the wiring connection and then reinstall. See if it works to stop the lamp coming on.
  10. Hmtz2014
    Hmtz2014 Bobtail Member
    5
    Did you ever figure out what the issue was? Same thing going on in my truck.
  11. sirjeff
    sirjeff Medium Load Member
    On volvos.... Interaxle light is solid, Locker(s) light flashes
    Normal! Carry on
