Anybody know the cost to have your dpf filter cleaned? Seen everything from 200-1800. It's s DD15 and will have to be done at a dealer correct?
I know how much the filters are. Hopefully a cleaning will take care of the fault code. Also how often is cleaning recommend? I had no idea it needed to be cleaned until I started researching this code. Truck has 440k no issues until now.
Diesel particulate filter cleaning
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tmichael2332, Jan 18, 2017.
I would definitely stay away from the shops that offer to do it for less than $800. It's not a cheap process. -
Depends on many things. The actual cleaning is about $200 if it only needs air, add about $200 if it needs to be baked. The rest of the cost is removal, installation, gaskets and doing a filter reset/regen. There are many configurations, some are easy to drop and others not so much. This is why you see a wide range of prices.
We do our own, just send them out for cleaning, but to do that you'll need the software to reset it in the ECM. If you haven't yet, it's a good time to have get the fuel doser cleaned (and SCR doser if you have one). It's a simple job that will save big headaches down the road. -
Malou Thanks this.
I think we have them done for about $450 CND.
I paid $550 for two epa10 dpfs at Detroit diesel.. just cleaning, no removal and installation. also paid $200 for new seals and clamps.
Malou Thanks this. -
Make sure the filter isn't cracked when it's cleaned
chevyryder86 and Deecutta Thank this.
