Diesel #2 or Kerosene
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blairandgretchen, Nov 13, 2013.
  1. blairandgretchen
    13,212
    70,211
    Dec 9, 2011
    South west Missouri
    Slightly off topic, but thought someone might know -
    My space heater for the shop says it uses Kerosene or Diesel for fuel. I've been using Kerosene, but it's far easier for me to get diesel for it.
    Which one burns the cleanest? Would diesel foul it up in any way?
    Thanks.
    KW Cajun Thanks this.
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    Is it a turbo-type heater ? My experience burning diesel vs. kerosene in these heaters is the diesel may be a bit more smelly or blast a little black smoke on start up but works fine. try it, won't hurt anything.
    blairandgretchen Thanks this.
  4. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    kerosene is cleaner,but you can use diesel just as well.make sure you pour fuel through a filter/strainer into tank.
  5. blairandgretchen
    13,212
    70,211
    Dec 9, 2011
    South west Missouri
    Yeah, it's one of those 'jet engines on wheels' 15,000 BTU Mr. Heater style space heaters.
    It's a 50 by 60 shop, so it's more a case of something to warm up in front of than trying to heat the space.
    Thanks for the strainer tip Q.TRUCK.
  6. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    I agree with the prior comments, also. I have a 60k BTU torpedo heater, same, just bigger.
    Be sure to top off its DEF tank also.
    No telling how much has been used up in the past Regen process! ;) :biggrin_25522::biggrin_25523:
  7. wore out
    wore out Numbered Classic
    15,319
    184,960
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I run red fuel in my heater has same effects as mentioned just a little cheaper per gallon and I generally have some on the place anyway.
    KW Cajun and blairandgretchen Thank this.
  8. KW Cajun
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Good point (and benefit) about the red fuel vs "street legal" diesel price.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I use jet fuel ore mix of jet fuel and diesel
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Kerosene burns much cleaner then diesel, but K1 kerosene burns cleaner then regular kerosene ;)
    Kerosene is much more expensive. There are guys using Waste Veggie Oil in their jet engine turbo mega heaters.
    Consider buying a fuel oil or waste oil furnace. A fuel oil furnace can normally run up to a 50% mix of waste diesel oil.
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    #2 will burn the dirtyest #1 is a bit cleaner than number 2 and kero is cleaner than all the above, all should burn fine in that heater.
