Diesel #1 vs #2 gel points in winter. Whats the difference?
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Jan 17, 2021.
  1. mitmaks
    mitmaks Road Train Member
    2,541
    2,064
    May 16, 2014
    What's gelling point of the two in winter time? Considering filling up with #1 when its really cold in northern states
  3. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    Coming from Wisconsin, we never ran straight #1. Not sure about modern trucks, but years ago we used to "blend" our own, say, 30% #1, 70% #2. Fuel in northern states is blended from the refinery, and probably good for 20 below right out of the pump. Any colder than that, not sure what they do? I suppose Ice Road Truckers would know,,,:rolleyes:
  4. hookster359
    hookster359 Light Load Member
    105
    174
    Sep 20, 2009
    mn
    If it is really cold out like 10 below or lower I try to put like 20 gallons of number 1 in each tank and than top it off with the blended fuel or if its straight number two I might even put more number 1 in like 30 gallons in each tank. I look at the price difference and than I think if I have to hire a tow truck or a mechanic that .10 or .20 cents a gallon difference is pretty cheap. In the reefer I always try to fill with number 1 so you have a good blend if you end up having to buy some fuel down south or out west.
    Doealex Thanks this.
  5. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    Just use a good quality Anti Gel. Plenty of them on the market.
  6. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    Fuel is usually treated with antigel when it's dropped at our northern locations.
    Some places sell premium fuel that is winterized. In addition to what they sell as not winterized. But most places that sell a volume of fuel have dealt with pour point issues on all or most of the fuel they sell for trucks. The pumps freeze up if they don't.
    Dave_in_AZ Thanks this.
  7. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Not all #2 fuel is treated the same. Ive had some not work below 10 and others go lower.
    Theres hundreds of videos covering anti gel...here's one
    Dale thompson, magoo68, Brandt and 2 others Thank this.
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Cloud point of straight #2 is like 20F..... gel point is probably low teens or high single numbers above 0F. That’s a guess from memory..........
    and bio blends are worse......
  9. mitmaks
    2,541
    2,064
    May 16, 2014
    I can't run straight #1?
  10. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    You can ..... if it’s cold enough I would. Otherwise it’s just a waste .
    you get less mpg and it’s harder on the top end also.....
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Just put some anti gel in is the easiest way. Every other fill up I put the small bottle in that treats 160gal and haven't had it gel up. Few times it's sat over a real cold weekend I pop the caps off and take a peek it was still fine not cloudy
