Detroit Thermostat Location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by areelius, Mar 26, 2014.
  1. areelius
    areelius Light Load Member
    270
    119
    Nov 9, 2012
    Temecula Ca
    Can someone give me a quick summary of replacing the thermostat or thermostats in a 1995 Series 60? I am a good backyard mechanic, but not a pro.
  3. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    follow the top rad hose back to the head and there in that housing
    areelius Thanks this.
  4. areelius
    270
    119
    Nov 9, 2012
    Temecula Ca
    Is it similar to a car therm, only bigger? You just pop it out and set the new one in? What temp. setting do you recommend?
    Thanks for the help.
  5. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    There's two I recommend whatever stock temp is, if colder the engine will stay in warmup mode and use fuel. Drain coolant, remove hoses, remove housing (four 15mm bolts that need 50 lb ft when putting back. Remove housing and two thermostats. Remove the two seals by pushing the at one point deeper into the housing, you have to crush them some to be able to pull them out. New seals I used a large socket (1 3/16 or something) to drive the new seals in. The rest is pretty straightforward. Hopefully I didn't forget anything. Try to do anythig else that requires drained coolant.
  6. areelius
    270
    119
    Nov 9, 2012
    Temecula Ca
    Thank you Allan5oh; that is the info I was looking for. Now I know its within my tools and abilities.
  7. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    It's actually pretty easy. I have the service manual in PDF format and could give it to you likely Saturday.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    S60's are one of the easier ones. The hardest part is getting the seals in straight without damage, just take your time. There is no housing gasket or sealer used to seal the housing, the thermostats have a rubber lip that seals to the housing. Make sure everything is clean to avoid leaks. I put a thin wipe of grease on the housing to help keep it from rusting where it's just metal to metal.
    Depending on the chassis, you may have a bleeder in the top rad pipe. If you do, have it open while refilling the antifreeze. Once coolant comes out the bleeder, close it and finish filling. Run it for about 5 min with the radiator cap off, then open the bleeder again to get any trapped air out of the pipe, top off the radiator and put the cap on.
  9. aktruckingcorp
    aktruckingcorp Bobtail Member
    Can I put little sealer around the housing?
