Detroit series 60 rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Chop528, Dec 10, 2023.
  1. Chop528
    Chop528 Bobtail Member
    4
    Dec 9, 2023
    Hi, it is time for an overhaul for me.
    I have a 12.7 detroit series 60 DDEV 4 2002.
    Run it at 650hp / 2150tq for many years.
    My engin guy rebuild it now as a 14L with crank, rod, piston and liner.
    I would like to have more low rpm power. I cruising at 1400-1425 rpm.
    what cam and injector should I use ?
    I run it with borgwarner s410 78mm for now.
    18 speed
    3.55
    11r22.5
    Thanks !
    blairandgretchen Thanks this.
  3. 062
    062 Road Train Member
    6,142
    33,153
    Oct 20, 2013
  4. Roanokemassey
    Roanokemassey Bobtail Member
    14
    5
    Jan 29, 2022
    Question,
    So you had a 12.7 bored and now using 14L crank rods and pistons?
    So what cam and injectors are you currently using?
    At what rpms does it start building boost?
    I am just curious what your current setup is?
    I find 2 variables that most don't talk about when talking about low range tourque.
    1. when does it start building boost? (Engine rpms)?
    2. What is the speed of the turbo when it starts building boost? (Turbo rpms?)
    When you let off the clutch, you need both fuel and enough air right then to make low end tourque.
    I think a lot of times bigger injectors, bigger cam, and a monster turbo will get you more Hp. That is great form something that runs all day at upper Hp.
    But we don't factor in how do we get from idle to crusing speed over and over again.
    What speed are you running?
    Flat, hills, or mountians?
    Do you have lots of start/stop miles or mostly cruising.
    Sorry for my long winded response. I just wanted to stress bigger injectors , cam and turbo may not help pulling heavy and wanting to get rolling fast.
    Bean Jr. Thanks this.
  5. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    What injectors are you running now as a12.7?
  6. Chop528
    4
    Dec 9, 2023
    I use R5237821 injector for now.
  7. Chop528
    4
    Dec 9, 2023
    Yes the engin was rebuild as 14L now.
    I use a 309 camshaft and 7821 injector on my 12.7.
    With the s410 turbo it start building boost at ~1275 rpm and be at 35 psi at 1350 rpm.
    Max boost was around 48 psi ~1650 rpm.
    I run on highway only. 50/50 flat and mountain.
    Most of time cruise at 1400-1425 rpm.
  8. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    The 309 cam is pretty good for highway driving. I really like the 7014 injectors. You can get great fuel economy with them, make a ton of power and they're not usually difficult to find.
  9. Chop528
    4
    Dec 9, 2023
    @benjamin260_6 I wild use the 7014 injector !
    For an future upgrade… I use s410sx 78mm turbo.
    14L HK
    7014 injector
    309 camshaft
    APC head
    Any turbo advice ? That a working truck… but you know we like performance to
    Bulleyes 83mm or go twin ?
    How much boost are you building with your twin kit when you are working?
  10. benjamin260_6
    430
    480
    Aug 8, 2012
    Ontario, Canada
    With stock pulsewidth (about 30 degrees) and 7473 injectors, my original compound setup would do over 60# boost but the gauge only went to 60 so I never found out for sure what it was doing on the track or pulling sleds. I've since tripled the size of the injectors and increased the turbo by 30%. I've seen over 110# a couple times but I'm still only giving it 50 degrees of pulsewidth at most.
    Compounds are great for racing or when you're making huge power on the weekends but still want good fuel mileage and drivability at work. However, I wouldn't really recommend compounds to the average person. An 80mm turbo can be pushed to well over 1000hp and still be set to spool up pretty good. Compounds are more complicated and much more expensive than a single so it can be hard to justify them.
    I'd consider trying that bullseye turbo. I never have but my LP turbo is a bullseye and I'm really happy with it so far
    AModelCat Thanks this.
  11. Fil72chevy
    Fil72chevy Bobtail Member
    I have a 12.7 detroit. 600 flywheel hp with a billet wheel 1702 turbo and stock (5575?) injectors. considering mfg a compound turbo setup. Any ideas on turbos sizes or good injector #s to go with it? would i need to bulletproof the engine to handle the hp if i did tht?? Would tht excessively harm engine longevity or mpg?? Is second turbo necessary or would bigger injectors get me to where i want to be? (700-800 wheel hp)
