Detroit Series 60 - New alternator question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Aug 12, 2012.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    I was looking to replace the alternator on my 99 S60 motor and noticed there are only a few options
    due to the rather odd mount they use..... Delco-Remy calls it a QUAD MOUNT:
    ...I'd like to see if anyone ever found some modification to change the mount style so that it can use one of the more readily
    available styles (like J180 or even pad mount):
    As it stands now, I need all 4 "ears" on this to mount and install it correctly..
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I'm running into the same problem. Mine has 270K on it, and I'd like to replace it with a higher output model (will have to add another wire to handle the increased capacity). I'm at home right now, and there are a couple of companies here that rebuild alternators and starters. I'll stop by and talk to them; I'm sure one of them will have a solution.
  4. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    Delco makes the 36si model that seems to be the highest output (170A) that comes in this style mount.
    $450 new...
    Bosch and the others simply don't make this style mount...
    Keep me posted. I am looking for something 200A+ output....
    crc32 Thanks this.
  5. Junkyard Johnney
    Junkyard Johnney Light Load Member
    209
    190
    May 27, 2012
    Plains,Mt
    I run a Detroit in my KW and it had this altenator on it, to expensive. All it has to do is go roundy roundy and charge the batteries, I bought on of those Leese Neville's that freighliner always has a pallet of on the floor selling them for just under $200 and put it on. From memory, as I did it years back, the lower mount is the same and you can make the upper adjuster mount work as far as that other top back mount? I just took the darn thing off and left it off. I have been running it that way long enough to be close to putting on #2 unit now and the pulley is worn out, not sure how long is that? These Leese Neville standard units are cheap enough I carry one in the box all the time, 1 hr to change from getting out to getting back in to leave. Hope it works for you.
    J-J
    RubyEagle and windsmith Thank this.
  6. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Do they come with a pulley, or do you swap the pulley from the Delco-Remy onto the Leece Neville?
  7. Junkyard Johnney
    209
    190
    May 27, 2012
    Plains,Mt
    Hang on a second Windsmith if you will , I will go look at my new unit, I got one out in the truck be right back...
  8. Junkyard Johnney
    209
    190
    May 27, 2012
    Plains,Mt
    Just looked at the new unit, remember this is just a standard unit not high output but it should be the same mount up. Anyway , no pulley, it has the cooling fan on it and the nut. Seems I asked Ray at Kenworth about that and he said they do not put one on because there are to many different ones, made sense. Most of the time if you have yours along with you they will swap out the pulley for you at the shop if you slip back there. I have done it out on the road before without an air wrench but it is a wrestling match. Oh, my pulley fit on the Leese Neville thats probably why it is worn out, 1,140,000 on the ole girl now...
    J-J
  9. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Thanks for the info. I'm assuming that your replacement alternator has what's referred to as the 'J' mount? I have the needed pullers and air tools to get the pulley on and off, but I was wondering about shaft sizes and the like.
  10. Junkyard Johnney
    209
    190
    May 27, 2012
    Plains,Mt
    Tag info
    Leece-Neville
    160amp
    200944
    110-555JHO
    Made in USA
    Mine the shaft size was the same, hope yours is too, it should be. I do not know what a pulley costs but I am going to find out in the next month when I replace all of mine for winter.
  11. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    I just picked up a new pulley for my 36si....$12.
    Wasn't worth the effort to deal with taking the old one off.. :biggrin_25520:
    windsmith Thanks this.
