Detroit S60 12.7 oil pressure
Discussion in 'Ask An Owner Operator' started by Tomek373, Jun 1, 2021.
  1. Tomek373
    Tomek373 Bobtail Member
    23
    5
    Mar 12, 2021
    Hi there I recently installed used Detroit s60 12.7 engine in my 97 fld classic, it’s a Detroit reman from 2012 and has around 300k miles on it(apperently) and came off from xpo day cab truck. My oil pressure when hot at idle is 26-27psi at 600rpm and when running 70mph at around 1500rpms it goes up to like 48-50 psi. Are these numbers still ok or should I get some things checked? I know my buddy with same motor runs 60psi hot at 1500 rpm. I am new to this motor so not sure if I am still in good range
  3. jamespmack
    213,347
    Your in spec. For a used engine. Might start doing oil samples to watch it. But your fine.
    Tomek373 and Mike250rs Thank this.
  4. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    I’m running the same pressure constantly as you posted. Normal.
    Tomek373 Thanks this.
  5. Rideandrepair
    17,209
    55,821
    Aug 8, 2015
    That’s normal pressure. Exactly what both my 12.7s have had. Before and after being overhauled.
  6. Tomek373
    23
    5
    Mar 12, 2021
    Thank you all for answers makes me feel much better now!!
    Speed_Drums Thanks this.
