Detroit DT12 shifting problems
Discussion in 'Western Star Forum' started by NorCenArk, Jan 18, 2023.
  1. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    My transmission revs up between even to odd gear shifts, 4-5, 6-7, 8-9,-10-11. It downshifts just fine. I have changed from econ. mode to performance mode and even manuel mode with no difference. I notice if i let off the fuel just before it shifts, it will not rev up. I have had the split pin issue fixed twice and have the clutch replaced at about 500000 miles when they had it out for last split pin issue. Has anybody experienced the same problems? If so, what did it take to fix it. Thanks
  3. Judge
    84,637
    When’s last time you’ve changed oil and the filter in the transmission?
    RocketyMan Thanks this.
  4. Timm1q
    Timm1q Bobtail Member
    11
    Mar 14, 2022
    Have absolutely the same problem.. Did you resolve it?
  5. NorCenArk
    76
    35
    Mar 31, 2011
    Russellville, AR
    No, haven't resolved it yet. Still searching for answers before I take it to stealership.
    Timm1q Thanks this.
  6. Timm1q
    11
    Mar 14, 2022
    Let me know please when you resolve this issue
    I will also keep you updated. Thanks
  7. Timm1q
    11
    Mar 14, 2022
    The strange thing that a few months ago suddenly it started shifting good for 10000 miles and after that with the issue again.
    Computer diagnostic doesn't show any faults
    I did also relearn transmission, no changes at all
  8. NorCenArk
    76
    35
    Mar 31, 2011
    Russellville, AR
    My transmission shifted ok for a while also then started doing it again. My next check will be to check TCM wiring harness along with pins to make sure no corrosion. Will let you know if I find something. Will be a few days.
    Timm1q Thanks this.
  9. Timm1q
    11
    Mar 14, 2022
    Did you find the solution of our problem?
  10. NorCenArk
    76
    35
    Mar 31, 2011
    Russellville, AR
    No, not yet. Trying to look
    No, not yet. Trying to review DT12 service Manuel and find a DT12 wiring diagram. I'm not been in big hurry because I'm semi retired and truck drives ok.
    Timm1q Thanks this.
  11. WesternSide
    WesternSide Bobtail Member
    Did anyone get this issue reso
    Did anyone get this issue resolved yet? Im having the same issues unfortunately.
