Detroit diesel 60 series problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GNVTrucking, Feb 12, 2019.
  1. GNVTrucking
    GNVTrucking Bobtail Member
    12
    7
    Feb 12, 2019
    I removed and deleted the EGR system on my 2006 Detroit 60 series. It worked great since. I just had motor rebuilt and went to pick up the truck 2 weeks ago and upon driving it on the highway with 26000 in the box, I noticed that the power was not there and that turbo wasn't spooling up strong til about 1600 rpm. It should spool up around 11 to 1200. Took it back to shop and there it sits. They have tried everything they can think of , a different used turbo and ECM. When we first put it on the computer it showed 3 pounds of boost with the engine off. Horsepower feels low and it was at 500 horse prior to rebuild. Have talked with the shop that did the delete and reprogram, they don't believe that it could have lost programming just from being without batteries for 3 to 4 weeks during rebuild. We may have to take ECM off and send it to the delete shop 3 states away. Or rebuild or replace turbo. According to the rebuild shop everything looks normal but the 3 pounds boost when shut off. I'm losing revenue every day it's down, and I'm pulling what's left of my hair out. What could it be? I've even asked a friend who works for Detroit building new motors and am awaiting a answer from their master mechanic. I'm lost!
    dibstr and Rideandrepair Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Maybe I am the idiot. But did you reflash everything possibly after the original delete? Maybe the engine is trying to work with something it no longer has and now is sick?
    Or perhaps derated on you because you essentially did a lobotomy on the emissions system?
  4. nikmirbre
    nikmirbre Road Train Member
    5,371
    9,543
    Jul 27, 2011
    High Point NC
    You still have the 14l turbo?
  5. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Atmospheric pressure sensor?
  6. GNVTrucking
    12
    7
    Feb 12, 2019
  7. GNVTrucking
    12
    7
    Feb 12, 2019
    Yes the ECM was deleted and reprogrammed at the time of the delete. It has worked great and has even lower emissions ever since. We think it may be a injector issue. Everything else ha d checked out good.
    x1Heavy Thanks this.
  8. Ridgeline
    22,101
    113,192
    Did they pressure test the CAC?
  9. GNVTrucking
    12
    7
    Feb 12, 2019
    Yes.
  10. nikmirbre
    5,371
    9,543
    Jul 27, 2011
    High Point NC
    That screw, I’m sorry I can’t think of the name of it.... I think it’s the actuator, it has to be in a certain position like 1/4 turn off of something.
  11. nikmirbre
    5,371
    9,543
    Jul 27, 2011
    High Point NC
    Or else your boost won’t be correct.... had a truck that had same issue. I’ve since put a BW turbo and took all of that stuff and pipes off along with a ceramic manifold
