Detroit diesel 12.7 series 60 turbo life expectancy?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by monaz25, Nov 10, 2023.
  1. monaz25
    monaz25 Bobtail Member
    4
    Nov 10, 2023
    Does anyone know the life expectancy of the turbo in the Detroit diesel 12.7 series 60 engine. I searched online for an answer I found nothing. And how often do I have to change the turbo on it
  3. DUNE-T
    DUNE-T Road Train Member
    6,876
    16,598
    May 10, 2015
    Detroit, MI
    Original turbo on original engine can go over a million
  4. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    While they can and often do last 600k or more. I would call it more of a maintenance item. They're not expensive, but it if it blows seals or loses a bearing, it can get expensive quick.
    My personal opinion, I'm gonna throw a new one on every 3-400k
  5. blairandgretchen
    13,216
    70,220
    Dec 9, 2011
    South west Missouri
    I second that opinion.
    I replaced mine around a million, because I had no record of it being done.
    cke, Rideandrepair and austinmike Thank this.
  6. blairandgretchen
    13,216
    70,220
    Dec 9, 2011
    South west Missouri
    BW171702 and a one piece manifold like Full-Tilt , some new boots, and some nice BH Tubes - give the old girl a Christmas present.
    You’re welcome - I spend other people’s money and charge only a nominal fee :)
    Ruthless, cke, Oxbow and 5 others Thank this.
  7. Stringb8n
    Stringb8n Road Train Member
    1,549
    1,919
    Sep 27, 2015
    Unrelated to the OP question, and I am not trying to hijack his thread here. But what would you say to someone replacing a turbo on a 12.7 Detroit 60 series who says: "there was a broken metal part, when we took the turbo off and we didn't have it so we removed the rest of the part and put the turbo on", whilst the engine still sounding just as it did with the old turbo after they put the new turbo on. The sounding being, as if air is escaping and hearing more air than you should. Sure seemed like that "broken metal part" was likely a gasket. Which was what needed replaced rather than the entire turbo.
    Rideandrepair and beastr123 Thank this.
  8. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    I've gathered the life of a turbo with fixed geometry (no actuator) depends a lot on how much thrust it is put under over time. I've had one go 900k. It had life but replaced during an inframe. You can put a machinists dial indicator mounted on a magnetic base to the compressor and turbine shaft to see how much play is in the bearings. Detroit has specs in their manuals. I found a set of manuals in PDF on 2 disc's for $20 on the internet years ago. The key to turbo life (and engine life for that matter) is easing into to the manifold pressure-no jack rabbit starts.
  9. MRMTRANS
    334
    372
    Apr 28, 2015
  10. HDiesel
    HDiesel Bobtail Member
    12
    11
    May 30, 2018
    I would ask to see the metal part, and old turbo to check the fins and play. It was probably a gasket.
    Stringb8n and Rideandrepair Thank this.
  11. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    You should not determine when to change something based on mileage, d60's turbos can last over 1mil. But can also fail in a few thousand, to determine if it's bad or going bad, look for oil in both sides intake and exhaust, grab the impeller and wiggle it up and down. A little movement is OK but if it's moving excessive or touching the housing then replace the turbo
    Rideandrepair Thanks this.
