Hello,
I have a 2013 freightliner cascadia with 13 speeds,455 hp,3.25 axle ratio,wheel base i think 240.
I have seen freightliners pull 2 axles rgn but very rare 3 axles rgn.
My friend has the Same specs on 2005 peterbilt 567, pulls 3 axles and 70 000 lbs with it and I was wondering if my detorit can do the same job ?
Detroit dd15 for heavy haul 3 axles RGN
Discussion in 'Heavy Haul Trucking Forum' started by UTS2015, Mar 27, 2019.
Page 1 of 4
The Detroit can. I do however, have doubts on whether the rest of the truck is up for it. The Pete is probably specced for it with heavier frame, heavier rear axles, heavier suspension etc.
ibcalm19, Tombstone69, Joetro and 4 others Thank this. -
Only if you put it in a peterbilt
jamespmack and QuietStorm Thank this. -
The truck and engine are fine. It's the 13 speed and 3:25 rears that's the killer.
It would be fine on flat land hwy hauling but forget about it if you have to go off road or in hilly terrain.mrbucbuck, Oxbow, jamespmack and 1 other person Thank this. -
His 22.5 low pro rubber would help too.......
jamespmack Thanks this. -
Heavy haul I'd want 3.73-4.56 range rears.... Depending how heavy !! Lol
The Detroit will do it... Idk about the rest especially the framejamespmack Thanks this. -
455 hp and 3.25 axles for heavy haul ?
Oxbow, jamespmack and 4mer trucker Thank this.
Oxbow and jamespmack Thank this.
SavageMuffin, Oxbow, jamespmack and 2 others Thank this.
Page 1 of 4
