Detroit air compressor shaft broken ?
Discussion in 'Ask An Owner Operator' started by pavrom, Feb 1, 2022.
  1. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I was driving today in ohio and at the toll gate my cascadia just shut on me . I was able to crank it up from second attempt , engine was running rough for 30sec at 300-400rpm so i was able to move from the gate to the shoulder , replaced fuel filters - same thing , 30 sec rough run , disconnected return fuel line from the head to find out that fuel is not going out at all , replaced fuel pump - same , figured out that air compressor shaft is broken after putting everything back together and fuel never came out of the fuel pump to the secondary fuel filter . Tried to start the truck with bucket of fuel -same ... guess meaning fuel lines ok . Waiting for the towing to come bring me to the shop for air compressor replacement in the morning . I was wondering what are the chances of stripped gear or any other issue beside air compressor shaft broken ?
    Rideandrepair and 77fib77 Thank this.
  3. Ridgeline
    22,103
    113,207
    What engine?
    Rideandrepair Thanks this.
  4. pavrom
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Detroit 12.7 series 60 1996
  5. CropShop
    CropShop Bobtail Member
    32
    18
    Mar 24, 2020
    We had that exact thing happen. It broke between the two cylinders, so it even pumped a little air. Took us most of a day to figure it out. It would start and run just a little, then die out. Best wishes.
  6. 77fib77
    77fib77 Road Train Member
    10,167
    62,764
    Jul 7, 2010
    St Louis
    What does the air compressor have to do with fuel supply?
  7. Rideandrepair
    17,204
    55,809
    Aug 8, 2015
    Small fuel pump runs off of compressor
    razor1983 Thanks this.
  8. Rideandrepair
    17,204
    55,809
    Aug 8, 2015
    Please update when you have more info. I had some chattering in the compressor/gear area yesterday that went away. Hopefully the gears are ok.
  9. pavrom
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I have a shim or spacer ( whatever its called ) between front plate and air compressor that had one of the gears got loose due to cotter pin destroyed holding it on the shaft . Spacer with gears is $1800 from dealer and its non existent in north America at the moment ( junk yard 250 ) , shaft dont even have key hole or something to hold cotter key in place , Detroit dealer advised to add additional washer and torque the nut holding the gear with gun ( dealer did twice within a year and no one came back ) , so 28 hours and $2000( road service, towing andshop labor ) later i was back on the road meeting midwest snow storm on i80 from toledo to iowa . So far 1000 miles - all good . Repair shop was very reasonable , knowledgeable and honest from start to finish .
  10. Rideandrepair
    17,204
    55,809
    Aug 8, 2015
    Thanks for the update.Costs seem very reasonable, and they got you rolling. The noise I heard sounds like it’s from that area. Compressors about 5-6 yrs old. Bull gear is recent. That part you show hasn’t been touched. Sounds like it’s fairly common. Shop did 2 recently, and parts being scarce. Gonna keep an eye or ear on it. Good thing the front cover didn’t have to come off. I’d say you caught a break on that one. Good to hear. Thanks again.
