Detroit 60 thermostat housing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Mar 26, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Does anyone know what the torque spec would be on the thermostat housing. Thanks
  3. lwlevens
    623
    427
    Feb 9, 2018
    Found it 43-54 ft lbs. If anyone else needs to know
    martican and Heavyd Thank this.
  4. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    I had a problem with mine leaking after changing thermostats had to use a little silicone to get mine to seal its wired as I know for a fact the thermostats have their own gaskets I’ve changed one on fuel island b4 it was that easy I think my gaskets were hardened up because they had been in side box for a while I never worried about torque should though I’ve cracked a few on cars over the years anyway don’t suppose you needed to use any sealer on flet surfaces
  5. lwlevens
    623
    427
    Feb 9, 2018
    Nope no sealer. So far so good.
  6. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    That’s what I thought must be mine were about 7 yes old kept them after dealer overhauled my last truck and put new ones in along with a turbo and water pump that I didn’t need but they do that for warranty what a joke thanks
