Detroit 60 series won't build air
Discussion in 'Freightliner Forum' started by Stepbrown75, Aug 16, 2022.
  1. Stepbrown75
    Stepbrown75 Bobtail Member
    8
    Aug 16, 2022
    I need some help with this problem. I have a 2005 freightliner century class s/t Detroit 60 series. I was on my way to pick up a load, then the back of my truck caught on fire ,burning my air lines( it only burnt some of the air lines on the driver rear side.
    Now that I have the air lines back connected it won't build air, but it was building air as it should before the fire. I had to get it towed,so is it something they disconnect? Please I need to work without taking it to the PIMPS.
    Thanks!!!
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    I'm sure it's just a line that was missed or maybe one of your air tanks has a valve open or a plug out
    Stepbrown75 Thanks this.
  4. Big Road Skateboard
    5,698
    29,730
    May 2, 2021
    You need to air it up without the engine running. You'll find it quick
    ibcalm19 and nikmirbre Thank this.
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Start with all emergency buttons pulled out, Rev it up to hi idle and look if dash gauges are showing any air pressure, but look at the air pressure reg. to see if it's gone bad, it's a cheap part and can be changed with a tool kit and just look at where the plugs are put in same holes and you should be building air in a few minutes
  6. Stepbrown75
    8
    Aug 16, 2022
    Thanks for the information, but how do you air it manual?
  7. Stepbrown75
    8
    Aug 16, 2022
  8. Stepbrown75
    8
    Aug 16, 2022
    It not building no air.
  9. Big Road Skateboard
    5,698
    29,730
    May 2, 2021
    I plumb into the discharge line on the compressor. Do you have an air compressor, like for air tools?
  10. Stepbrown75
    8
    Aug 16, 2022
    No, but I'm going to buy it now.
  11. Stepbrown75
    8
    Aug 16, 2022
    Yes I have an air compressor. sorry for the confusion.
