I have an opportunity to purchase a 2001 Freightliner Classic with a blown head gasket for. I don’t have the money for a full rebuild done the right way, and I’m wondering if only the upper gasket set was done on it is it possible for it to last even 2 months? I know the counter bore *should* be done, but if the the protrusion was off a little, would that just blow the head gasket again immediately? In two months running it, it would pay for itself 3 times over and I could then do a real overhaul with heads, injectors, etc. I don’t think the guy ran it as soon as it became clear that the head gasket was blown, so I would think the pistons are in good shape, but I could have someone come over and borescope it potentially. If it isn’t even possible for it to run a few months, I’ll probably just go a different direction and get one that doesn’t have an immediate need for a repair, as I’d rather have a different truck if I’m planning on investing in the cost of an in-frame right off the bat. What would labor on replacing the upper gasket set cost? Thanks
Detroit 60 series blown head gasket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by VolunteerTrucker, Dec 16, 2023.
Page 1 of 3
How much is he asking for the truck?
VolunteerTrucker and Big Road Skateboard Thank this. -
12.7 or 14lL?
Rideandrepair and VolunteerTrucker Thank this. -
Rideandrepair, Big Road Skateboard and Iamoverit Thank this.
Rideandrepair and Iamoverit Thank this.
What state are you in? Usually you can find a mobile guy to do the cutting. Last time my guy quoted me about 500 to travel and do all 6 holes plus chamfer the insides on a CAT.
Pull the head and check for liner scoring. Pull the pan check the bearings and crank journals. If it all looks good call a mobile guy and have him do the work and you can put it together.
You could send the head out for just a couple hundred more and get it decked and checked for cracks too.
Or you could just throw it all back together with nothing but a new gasket but I would go over it real well so you won't waste too much money and aggravation on it.VolunteerTrucker Thanks this. -
Rideandrepair, W923, VolunteerTrucker and 1 other person Thank this.
At the end of the day, I could even do the counterbore too. I know that’s gonna be pretty important for that old of an engine, if I did the counterbore now and did a full rebuild in a couple of months it probably wouldn’t need that again, right?
Rideandrepair Thanks this. -
Might get a couple months out of it just slapping a head gasket on depends how bad the counter bores.
Page 1 of 3
