We have an issue with a 2011 Detroit 60 ac compressor mount. Over the past few months the top bolt on the mount keep breaking and then backing out and rubbing on the ac/alternator/water pump belt. We have tried using grade 8 bolts as a replacement and they keep breaking. Any suggestions or after market parts that we can change this out with?
Pictures
Detroit 60 AC compressor mount bolts keep shearing off
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CGYMIKE, Mar 10, 2021.
Page 1 of 3
Pictures
Is that a 3/8" bolt in a 10mm bolt hole? How tight are you tightening it?
I had the same problem. The bolt holes on the front cover get egged out allowed the bolts to move. Best bet is to get a different compressor that mounts using three bolts through the front cover instead of two. I did see a engine that had the bolt holes reamed out, then sleeved with a harder metal to run the bolts through. Guy said it was doing the job but I never saw him again so I can't tell if that worked. I saw another guy that changed to grade 8 bolts. Don't do that. His bolts lasted longer but ended up egging the holes in the block out too.
bumper Jack Thanks this. -
bumper Jack and CGYMIKE Thank this.
Page 1 of 3
