Got a egr motor d60 14l. Getting heavy oil in coolant. New oil cooler, no fuel in coolant just oil, and no trans cooler in the rad. I'm thinking only other place oil could come from is the head? Liners would put coolant in the oil correct?
One other thing this truck was just purchased and I noticed both heater cores were busted, I'm thinking the owner let it freeze and cracked the head
Detroit 60 14l oil in coolant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Transportauto, Oct 30, 2023.
Another source could be from the air compressor...
Rideandrepair Thanks this. -
OK so air compressor. I have only had water in the tanks or oil in the tanks. Coolant is only in the head of the air compressor right?
There isn't any oil passages in the compressor head is there?Rideandrepair Thanks this. -
Have to go back to never say always and all ways say maybe.
Had a 350 Big Cam doing that and replaced the oil cooler. No coolant in oil from the drain plug. About 3 weeks later it got a lot worse. It had a cracked liner.
Maybe get to operating temp and drop the pan. Check it out. Turn the crank 1/2 turn and check it out. If you do not see anything do it again tomorrow when it is cold. This does not cost a lot of money ether way right or wrong.Rideandrepair Thanks this. -
