Detroit 60 12.7 Jake brake compatibility
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Freightshaker03, Jan 29, 2022.
  1. Freightshaker03
    Freightshaker03 Bobtail Member
    23
    16
    Apr 11, 2021
    Hello, hope I’m posting in the right place.
    On a 2003 60 series 12.7,
    Does anyone know if I can swap my original set of 795 Jake brakes with a set of 797’s?
    The only difference I can see is the 797’s only have one solenoid per head vs the 795’s that have 2 on one head and one on the other…
    I am assuming I can just use 2 of my 3 wires and I will then just have 2 settings rather than 3?
    Anyone know if there’s any issues with that?
    I’m thinking the 797’s are off a newer motor? Or a 14l?
    Any advice would be greatly appreciated!
    Tank you!
  3. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
  4. jamespmack
    213,523
    Is your 2003 a Pre Egr or Later egr engine. Alot of 2001 engines were pre-order and purchased for 2003 built trucks. Especially detroits in KW/Petes.
  5. Freightshaker03
    23
    16
    Apr 11, 2021
    It’s pre egr.
    Does that make a difference for jakes?
    jamespmack Thanks this.
  6. jamespmack
    213,523
    Sure does. YOU Certain you numbers are correct? DDC4 was in 2003 pre order trucks non egr. DDE5 was in 2004 calander year.
    Now, I am no DDEC5 guy. But sounds to me your mixing generations with your description and only 2 position jake selection. Id be very careful mixing parts.
  7. Freightshaker03
    23
    16
    Apr 11, 2021
    Yes my truck is a 2003 fl classic ddec 4 with a 2 Jake switches which have 3 settings, left switch low right switch med both high.
    Make sense?
    The 797 jakes that I bought are probably from a ddec 5? The only real difference I see is only 2 solenoids not three…
    I really hope I can use them because I can’t come up with a decent set of 795’s unfortunately.
  8. jamespmack
    213,523
    Why replace when they are simply rebuilt at home. However im betting they are 770 Jakes. 3 units, reliable and dependable.
  9. Freightshaker03
    23
    16
    Apr 11, 2021
    Mine are beyond rebuildable unfortunately! I did rebuild once already.
    But one dropped a piston and busted the housing.. which I’ve already welded back together and used for a while like that… lol
  10. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Where are you located? I have several sets of jakes at the shop. We are in SC. I might have what you need.
  11. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    As far as Bolting the dd5 jake to the dd4 will bolt on if you use all the bolts and spacers from the dd5 as far as working no ide plus what are you going to do with the 3rd wire letting it hang will give a cel
