Detroit 11.1
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Aug 28, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Hi all a buddy of mine has a 2000 Detroit 11.1 think it has 365 hp. He wanted to know what he can do to get more out of it. Thanks in advance.
    Dino soar Thanks this.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Pittsburgh power can get all of the power you went. It's not cheap, maybe 600 hp.
  4. lwlevens
    623
    427
    Feb 9, 2018
    I think 600 hp will blow it up???? Thanks.
    tnpete Thanks this.
  5. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Did they not stop making the 11.1 in what 1998? If that is right he would have a 12.7. That or someone has put the 11.1 in the truck.
    They say the 11.1 is only rated at 365Hp. But some were up-rated to the 400 HP rating. Detroit did it to a bunch of used trucks. To make them sell better, or that's what I have read.
    My 1995 11.1 started life as a 300 HP engine. Then when the ECM was changed out. They had to put the DDEC-IV ECM on it. And from what I have been told. You only get the 400 HP rating with that ECM. Buddy of mine is going to hook it up to his Pro-Link. And then find out what its rated at now for sure.
  6. lwlevens
    623
    427
    Feb 9, 2018
    Yeah let me know. I think 400 hp is Max for the 11.1...so I heard.
  7. tnpete
    561
    609
    Jun 25, 2013
    Tn
    I ran the first year 11.1 . Truck was 2 years old then. And Being it was a O/O truck. Had it cranked up at Detroit in Memphis Tn. Have not ideal what they set it at. But Man did that little engine pull and run.
    I could hang with most trucks. Top speed was 87 MPH on it. Fregihtliner and 10 speed trans. And it pulled great also for what it was. Pulling the little hill on Hwy 157 in Al before you get to Cullman Al. I could pull it in 7th gear. That was back when it was 2 lane until you got to the hill. Battle Ground Mountain is what the locals call it. Not a giant hill, but back in the late 80's it was a pull.
    Rideandrepair and Mississippi129 Thank this.
  8. lwlevens
    623
    427
    Feb 9, 2018
    I'll call Pittsburgh power and see what they say. Thanks
  9. Rideandrepair
    17,212
    55,865
    Aug 8, 2015
    My 01 Freightliner has a nov 1999 12.7 original factory
  10. Rideandrepair
    17,212
    55,865
    Aug 8, 2015
    Very economical engine.Fuel sipper. Wouldn’t want to change that or spend a ton of $$$$ trying to make it what it ain’t. Why not run it and build a 12.7 with all the fuel savings
  11. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    You can do everything to a 11.1 that you can do to a 12.7 or a DDEC 4 14L. Ecm tune, bigger injectors, bigger cam, bigger turbo, high flow exhaust manifold etc. You're not going to get as much power as the bigger displacement engines but you can still go at least 50% over stock and still have a reliable engine.
    RubyEagle Thanks this.
