detriot series 60 how to get more power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by s hauler, May 3, 2010.
  1. s hauler
    s hauler Bobtail Member
    23
    8
    May 3, 2010
    Saginaw Mi
    i have 1998 freightliner with a series 60 detriot 12.7 liter set at 470hp i have heard of owner ops getting alot of power out of these does any one now any tricks or tips or modes i could do for more power i now it will never be a 550 cat i just need more power i pull a 9000 gallon quad axle tanker and gross 115000 pounds i love the mpg it's average is 5.5 to 6 please any help would be appreicated thanks
  3. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    No matter what brand the engine is, recipe is always same = marine or some other bigger injectors, bigger turbo, ECM programming and that's it. 1000+ horsepower easily from any modern engine over 12 liters.
  4. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Before you start all this power thing, you have an old truck, and the reason you drive it is to MAKE MONEY. Will your clutch, transmission, drive line, rear suspension, and rear ends, handle the extra power. How about the radiator, what is a 5 core worth, Charge air cooler, you will need new motor mounts. The longevity of the motor will be a lot less, and your fuel mileage will be a lot less. If you lived closser I would do the work for you. Just a thought!
    jtrnr1951 Thanks this.
  6. s hauler
    23
    8
    May 3, 2010
    Saginaw Mi
    thank you for the advice i have a brand new clutch and 13 speed to put in all new bushing in rear brand new radiator but yes it is a older truck but it is what i could afored at the time and i have to make it work for now i will be hooking on to a set of double tankers in a few weeks ani will gross 151000 and need alittle more power just looking for sum little tricks and maybe a couple website to look for parts or some people to talk to about detriots every i talk to around michigan now cats any help would be apreciated
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I have yet drove a truck with a Detriot that has pulled worth a ####. I think the engines are garbage period. I don't see it fit to waste the time or money to fix one up. No way would I ever buy a truck with one in it. Not much choice when having to drive someone else's.
  8. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    Not true if built right.
  9. JohnP3
    1,594
    683
    Feb 21, 2010
    I have been doing this for a long time and, I have heard all the experts making all the big power and getting better fuel mileage. Well I do not want to be the bearer of bad news but it takes fuel to produce power. Can you with experience get better mileage than stock "yes". I was reading one post and the guy is saying he is running up to 3000 RPM well I can tell you that anything above 1800 and you are loosing, burning fuel, and producing heat, putting a lot of stress on the motor. Not a whole lot more, you want power do a valve set, be sure the rad and CAC are clean, have the CAC tested for leakage, check you fuel pressure and be sure it has no air in it. Do a flush in the cooling system, the more efficient you make every little system the more power you have to drive the truck and make you money. Just a thought!
  10. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    2 words==== bully dog===more power/ better fuel mileage
  11. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    But you also have to inject it the right time, stock engines don't do it. Retarded timing wastes fuel, it just makes heat, not power. When you change bigger turbocharger you lower backpressure and you don't need as much fuel to push exhaust gases out. It's kind of "free horsepower", less fuel, more power. In other word better efficiency. Remember I am talking about clean burning high hp engines, not those "cool" "turned up" amateur builds smoking like crazy.
    When you have more power from same size engine you can climb hills faster with less gearchanges and again you use less fuel. That's a proven fact, by economy driving teachers, and by experienced drivers.
