Detention time
Discussion in 'Ask An Owner Operator' started by W Bench Farms, Dec 16, 2021.
  1. W Bench Farms
    W Bench Farms Light Load Member
    210
    351
    Oct 16, 2017
    Haven't had much of a problem yet with wait times, but have had a couple of shippers and receivers that are slow. Most of my brokers state detention time after 2 hours. Several say they need to be notified 1 1/2 hours in. I know they all try to get out of paying. Do you just let the broker know that there will be detention time and add it to the invoice? Just want to figure out the easiest way to get this taken care of. Sitting at a construction site now, had 3 trucks ahead of me. Have been here for just over an hour and still a truck and 1/2 ahead of me. Detention time has always been a little confusing, and I know the brokers don't want to give any info on it.
  3. rollin coal
    rollin coal Road Train Member
    13,080
    25,856
    Mar 29, 2008
    TN
    It's not complicated. Do these things and you will get paid detention. Get your detention terms agreed to and in writing when you book the load otherwise you are at the mercy of the broker and that seldom ends well. Do a check call when you arrive at their customer. You notify them 30 minutes before detention starts. You make a note of your "in", "out" and "appointment" or "arrival time" on the BOL and if you can't get the shipper or receiver to initial or sign beside that you either put their initials or signature on there or put your own initials or signature there. Either one has always worked for me and never been questioned. Normally when somebody gets screwed on detention it's because they didn't do one or more of these things.
  4. BennysPennys
    2,351
    22,225
    Sep 24, 2021
    ProfessionalNoticer Thanks this.
  5. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Call them & email them so you have documentation. Put your in & out times on the bol so you have a signed bol with your times. It is all about documentation & communication.
    feldsforever Thanks this.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Most times they'll send over a revised rate con with detention added
  7. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I do dryvan but I email the broker when I arrive before my appointment time.
    If they have not begun to unload me at an hour or an hour and 1/2, check your rate con that usually will tell you how to deal with the procedure for detention, between an hour to an hour and a 1/2 I call them and say Hey these guys haven't started on me it looks like we may go into detention what's the correct procedure? If they are good with email with replying I will use email.
    Almost every broker has said to me to just keep track of my times and write it on the BOL.
    And I also continue to check in with them if we're at 3 hours or 4 hours I don't just sit there I call them and say Hey still here just wanted to give you an update. Often when you call them they will call over to where you are and say Hey I got this guy getting unloaded can you get him out of there your paying detention.
    Then if there is a gatepass or anything that has my time in-and-out on it I will Scan a copy of that for my records.
    As soon as I am empty before I even leave the place immediately I send the broker the BOL with the in-and-out outtimes on it and I request a new rate con.
    Sometimes it gets sent over maybe within 5 or 10 minutes sometimes it takes until the following day and sometimes you have to follow up with them on sending it but thus far that has worked out for me.
    It is best if you can email them and ask them the procedure because there are a few brokers that I've worked for that sending the BOL to the broker himself is not enough. Some brokers have another department that you have to send the lumper receipt to or the BOL itself to them in order to get paid the detention.
    Time is of the essence with sending them the BOL and following up with them because there's really only a certain time frame that they like to ask for detention. If you wait a couple days or a week and try to get it it's probably not going to happen.
    Accidental Trucker Thanks this.
  8. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    RC has it all. In fact, he's one of the posters that taught me when I was researching here on TTR several years ago when I started my business.
    I do things slightly different but the general gist is document everything and get it all in writing. I've even gotten paid with just an agreement in an email message. It wasn’t even on the rate con.
    rollin coal and BennysPennys Thank this.
  9. W Bench Farms
    210
    351
    Oct 16, 2017
    I appreciate the replies. I don't want to irritate any brokers, but these long wait times mess up my schedule, and make it tough to reload. Seems like it's been getting worse the last couple weeks. I've been waiting this morning going on 3 hours, and 5 trucks sitting behind me. FCFS delivery today. This is a broker I haul for pretty regularly, so hate to complain and quit getting loads because it's close to home to deliver. Luckily I'm headed home when I'm empty, but if I had a reload it would sure mess things up.
  10. rollin coal
    13,080
    25,856
    Mar 29, 2008
    TN
    Yeah forgot to add, and it was mentioned above in another comment, always request an updated rate con with detention added on. Usually they're going to want to see a scan of your POD where you've got your "in & out" times and signatures etc. The good ones will send over an updated rate con right away but most of them make you wait a day or longer while they verify.
  11. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Well, you're going to have to either raise the rate to cover what you need hourly to sit or be fully prepared to pass on those loads. Sometimes these decisions can be challenging for some people. You'll get a chance to see just how great your broker is (or isn't) after you break the news.
