Depth perception
Discussion in 'Questions From New Drivers' started by leonsls, May 2, 2010.
  1. leonsls
    leonsls Bobtail Member
    24
    12
    Apr 25, 2010
    Okay, in a week I go out to the range to start playing with REAL trucks and learning how to back and manuver them.
    My biggest concern is I seriously lack depth perception. The impression I'm getting from instructors is that it can be handled and not to worry about it. I am worried about it and if I can't drive a truck because of it, they still have their money in the end.
    Is depth perception something that can be dealt with. I know I'll have to GOAL alot and have no problems with that. I'm just looking for to see what others have to say on the subject.
  3. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    Always good to GOAL! I know it may not seem like it now but eventually you will develop the needed skills. It will take time and practice but before long you will be able to blind side back into an alley dock with the rising sun right in your eyes! Just don't let other people rush you and if you are in doubt, GOAL!!!
    navyvet1994 Thanks this.
  4. red_eye
    red_eye Medium Load Member
    430
    122
    Dec 30, 2009
    belpre, ohio
    you will also be able to to use timing..on the range.. like when I'm blind side parallel.. I lose the cone in my right convect mirror ..right before I lose the cone on the right.. I count to 3 ..then I can go back to center point and bam..Im right on spot...I know it wont work too well in the real world..but it works on the range..but to a point it will..but I can get out and look..more then 2 times in the real world..lol
  5. navyvet1994
    navyvet1994 Light Load Member
    51
    Nov 13, 2010
    Old Orchard Beach, ME
    Thanks to both of you. I have vision in both eyes but I see the world at one eye at a time so my depth perception is pretty messed up. It looks like good math skills will help in backing, but what about see forward. the hood is pretty long and it seems to be easy to not see a car right on top of the grill. any ideas???
  6. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    stay back and dont let the cars get under your grill
    even at stop lights---make sure you can see their tires
  7. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    this will only work for when he is practicing and then later at the DMV to take the tests......HOWEVER, as i have said numerous times, i deal with the DMV test sites and i can assure you the cones/flags are NOT ALWAYS located exactly where they are at the schools. so now what does one do with "timing" and sight of the objects..??? it can only be used as a "generic guide" and to never be relied on 100% of the time. the only "near sure thing", is to G.O.A.L.
    now here this is true. this is what we tell them. "if you can see the ENTIRE rear of the car in front of you including the tires touching the ground, you have a pretty good distance. DO NOT go by just the sight of (say) the license plate"..
    but sadly we know all too well, there are too many truck drivers that make sure they take up ALL that space in front.
  8. guineverejast
    guineverejast Bobtail Member
    I have the same issue and I was just wondering how you were doing? Are you having any problems? Thanks
  9. FCW9
    FCW9 Light Load Member
    114
    46
    Jun 12, 2012
    Baldwisnville, NY
    When I get out and look I pick out "land marks" to try and spot up with as I do a maneuver. There's something different about cone 3 let's just say for the sake of argument. well that's about where I need to aim for anyway so i don't over shoot my blindside parallel back. So, as I go back, I'm checking my mirror, AFTER I'VE DONE MY WALK AROUND, and when it looks like my trailer duels are even with it, that's where I stop.
    I've found it's easier to see when 2 objects are across from each other than try and judge how far from the end cone I am.
  10. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    Depth perception can be a problem, even with 20/20. Isn't that why a driver you're passing will flash you in ? Because you're not sure you have cleared him, right ? Also, go to any truck stop with a fence behind the back row and observe how the fence is leaning from being backed into so many times.
