delta tune
Discussion in 'CB Radio Forum' started by Brownietrucker24, Mar 1, 2012.
  1. Brownietrucker24
    Brownietrucker24 Bobtail Member
    13
    Feb 21, 2012
    detroit michigan
    What is the Delta tune knob for and how do u use it best
  3. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    Setting Delta-Tune
    Delta-Tune functions as a “fine tune” control
    enabling you to capture a more readable signal,
    as well as eliminate adjacent channel interference...
    :biggrin_25520:
    Brownietrucker24 Thanks this.
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    It IS a fine tune and back in the old days because under the old rules you could be almost +/- 2 khz off and be legal
  5. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    On a Cobra type radio you put it in the middle and leave it alone, or convert to a band switch when you put a channel kit in your radio.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    On Cobra radios it's there for guys who run Amps...They have it converted to a Variable Power knob so they can adjust their DK... Why Cobra don't just do this from the factory, I have no idea because the Delta Tone feature is really pointless...
    Galaxy CB Radios have a Variable Power knob and are FCC certified...As long as the adjustable power does not exceed 4w's, Cobra could have this already on their radios...
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    It can also be used to put in an echo knob. Then you use the Ch 9 switch for a roger beep. :biggrin_25525:
  8. mike5511
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Yeah that would be a good use also. I just used one of the switches for hi/lo pwr, because I had the channel kit in mine.
    Never added a roger beep......do people really do that?????? I have added channel kits and connex boards......wouldn't do it again, would just buy an export to start with......but never roger beep, burp, fart or any other obnoxious toy. (confession, did have a Echo Max mic on a bast station one time, now there's a roger beep for you!!.....but it had an on/off switch)
  9. Brownietrucker24
    13
    Feb 21, 2012
    detroit michigan
    What's a channel. Kit
  10. Mud Dog
    Mud Dog Tattooed & Insane - Forum Sparkler
    695
    576
    Dec 8, 2009
    Devil's Land, kentucky
    I set mine half or just right and everything seems to sound good. Have maxed it out before to hear/understand those echo freaks. A little sounds good but do ya hafta sound like robo cop in a 5 gal bucket?
  11. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    It should not matter even with echo unless they are so distorted that they are producing FM .... the Delta/tune should be wide enough to account for the legal bandwidth of center frequencies ( +/- about 2 KHZ from center ) with todays PLL loops things should be even tighter ....
