Deleting a paccar
Discussion in 'Ask An Owner Operator' started by Soonerman51, May 29, 2020.
  1. Soonerman51
    Soonerman51 Bobtail Member
    May 29, 2020
    I have 2018 paccar motor . Has deleting it helped or hurt ? Tired of the codes related to DEF issues coming on and off. And shop time
    Midwest Trucker Thanks this.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    What are your codes?
    There are guys here who really can help.
  4. Soonerman51
    May 29, 2020
    3130.. it’s for the def temp sensor . It comes on and it goes off. Can cycle the key and it will go away and come back .
  5. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    @longfld just posted about a wire harness problem
  6. Midwest Trucker
    5,912
    21,382
    Aug 31, 2018
    Thats what came to my mind as well.
    @Long FLD
    Deere hunter Thanks this.
  7. AModelCat
    161,251
    Probably not going to get any info about deletes. The owner does not want it discussed on their website.
  8. Long FLD
    Long FLD Road Train Member
    12,441
    51,586
    Mar 4, 2015
    Unplug the main harness from the ecm and then cut all the ties that keep the wires inside the driver side frame rail. You should have 6ft of wire to stretch out in front of your firewall once everything is loose. Then start inspecting wires. Chances are they kinked one or one rubbed a bare spot.
    I bought the truck I have now with 244k on it. The previous owner chased phantom codes like you describe until they pulled the main harness and inspected each wire. Peterbilt in Garden City told me they’ve seen this issue on quite a few MX powered trucks. It seems they bundle the wire up too tight inside the frame rail and causes some pinching and kinking. Happy hunting.
    Bains, Dale thompson, Coffey and 5 others Thank this.
  9. Soonerman51
    May 29, 2020
    Thank you !
  10. Long FLD
    12,441
    51,586
    Mar 4, 2015
    You bet. Hope that cures it. I’ve put 223k on mine since I’ve had it (has 467k total) and knock on wood I haven’t had any issues. I know the previous owner and they would just clear the code and he’d keep trucking. It ran fine, it would just have the light on.
  11. Atlanta trucker
    Atlanta trucker Road Train Member
    1,605
    2,003
    Jan 25, 2017
    I deleted all of my Cummins ... what a huge difference !!! 2-3 gallons per mile increase in fuel mileage , more power , smoother idle , cleaner oil everything was better. We did a lot of other improvements also so that helped a lot to. But these newer more modern engines I don’t know to much about.
    Coffey and Chubby Fly Thank this.
