Deleted Cummins ISX Not Communicating
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Company Wrench, Feb 1, 2025.
  1. Company Wrench
    Company Wrench Bobtail Member
    5
    Feb 1, 2025
    I have a new to me 2012 Peterbilt with a deleted Cummins ISX 15L that I don't have access to the history on. The jakes are not working at all. The computer I have is not communicating with the ECM thru the 9 pin. I am wondering if the ECM was "locked" during the deletion process? So far we've checked fuses and found a few missing. Thoughts?
  3. Arctic_fox
    3,861
    19,407
    Sep 16, 2016
    Sorry mate, forum rules mean we arent allowed to give too much advice on deleted vehicles. Especially on the computer side of things. That said good luck, there are many ways to delete a rig and some of them can really mess up the engine.
    Bean Jr. Thanks this.
  4. snicrep
    snicrep Heavy Load Member
    952
    1,722
    May 13, 2009
    mcallen, tx
    How about this site ease up on the censorship a bit?
  5. intrepidor
    intrepidor Medium Load Member
    378
    847
    Aug 24, 2017
    Western Iowa
    Trump says its ok to lighten up or you'll be replaced.
  6. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    It’s a ‘no discussion’ topic for legal reasons. It’s posted in the forum rules.
    Legal issue. If the rules weren’t in place it’s dubious if this forum would exist.
    Oxbow Thanks this.
  7. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    I think the EPA has more to do with this issue.
    Oxbow Thanks this.
  8. broke down plumber
    2,537
    17,926
    Jan 25, 2024
    If knew anything i'd offer it , to hell with censorship.
    little cat 500 and Bean Jr. Thank this.
  9. AModelCat
    154,244
    I'd start and see if you have power and ground at the 9 pin plug. I haven't had to deal with the J1708/J1587 before, not even sure its even used much anymore. With key off you should be seeing roughly 60 ohms resistance between pins C and D. You can check voltages. With very little activity on the network you'll probably read slightly above 2.5 volts on Can Hi and slightly less than 2.5 volts on Can Lo.
    Goodysnap, bjytech, D.Tibbitt and 4 others Thank this.
  10. bjytech
    bjytech Light Load Member
    229
    207
    Nov 9, 2013
    Cummins has a backbone J1939 plug on the engine, usually right there on the intake manifold on the ISX(triangle 3 pin deutsch plug) that is my go to with cummins engines if the 9 pin isn't communicating with the engine.
    If the harness going back the the DPF is missing or un plugged that can also cause issues on the engine side J1939 since one of the J1939 terminating resistors is in that harness.
    Heavyd and D.Tibbitt Thank this.
  11. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    he's not trying to delete it mabe hes un deleting it help the guy out
    D.Tibbitt Thanks this.
