Def tank sucking in
Discussion in 'International Forum' started by Twista89, Nov 5, 2020.
  1. Twista89
    Twista89 Light Load Member
    86
    39
    Oct 2, 2017
    So for a few months now when I go to fill up the def and break the seal with the pump handle it starts to suck in air like it’s under vacuum. The tank is starting to cave in as well. Does anyone know what would cause that?
  3. Just passing by
    Just passing by Road Train Member
    1,177
    3,140
    Feb 25, 2017
    I had the same issue some months ago. It's a valve inside the tank that's not letting air in as fluid level goes down. You will need to have it replaced. I don't quite remember all details but KW west Atlanta replaced it in just a few hours.
    Dave_in_AZ Thanks this.
  4. Dave_in_AZ
    370,744
    Seen a MACK with a massive aluminum DEF tank the other day. 30 gallons? 50?
  5. AModelCat
    154,582
    Aluminum? Ain't gonna last long before that DEF eats it up.
    magoo68 and Roberts450 Thank this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Likely plastic coated on the inside.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Tank vent plugged or not working right. Usually on top, may have to take off a cover to get at it. Not expensive.
    Goodysnap Thanks this.
  8. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Yep, vent is plugged. The vent hole is located in the head unit, where the coolant and def lines connect. There will be vent line coming out and just draped down the back of most tanks. Take the line right off and look into the nipple at the head unit itself. This is where most of the blockage is. It will be just dried crusty DEF fluid. Chip it out with a screw driver or coat hanger.
    devedo, Flint1 and uncleal13 Thank this.
